Ir para o conteúdo principal
Acer Swift 3 2022 Touchpad Replacement
O que você precisa
  1. Acer Swift 3 2022 Touchpad Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Be sure to power off the laptop before starting.
    • Flip the device over so the bottom panel is facing up.
  2. Acer Swift 3 2022 Touchpad Replacement: passo 2, imagem 1 %32 Acer Swift 3 2022 Touchpad Replacement: passo 2, imagem 2 %32
    • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
  3. Acer Swift 3 2022 Touchpad Replacement: passo 3, imagem 1 %32
    • Use the iFixit opening tool to pry open the back of the device.
    • Remove the bottom cover from the laptop.
  4. Acer Swift 3 2022 Touchpad Replacement, Battery: passo 4, imagem 1 %32 Acer Swift 3 2022 Touchpad Replacement, Battery: passo 4, imagem 2 %32
    • Peel back the strip of black tape.
  5. Acer Swift 3 2022 Touchpad Replacement: passo 5, imagem 1 %32 Acer Swift 3 2022 Touchpad Replacement: passo 5, imagem 2 %32 Acer Swift 3 2022 Touchpad Replacement: passo 5, imagem 3 %32
    • Unplug the group of wires by pulling the white plastic piece towards yourself.
    • Be careful, this piece can be easily damaged.
  6. Acer Swift 3 2022 Touchpad Replacement: passo 6, imagem 1 %32 Acer Swift 3 2022 Touchpad Replacement: passo 6, imagem 2 %32
    • Remove the two 5 mm screws on the sides of the battery using a TR6 Torx screwdriver.
  7. Acer Swift 3 2022 Touchpad Replacement: passo 7, imagem 1 %32
    • Remove battery.
  8. Acer Swift 3 2022 Touchpad Replacement, Touchpad: passo 8, imagem 1 %32
    • Before disassembly, place a sheet of paper or cloth material between the touchpad and the screen.
  9. Acer Swift 3 2022 Touchpad Replacement: passo 9, imagem 1 %32 Acer Swift 3 2022 Touchpad Replacement: passo 9, imagem 2 %32
    • Using the iFixit opening tool, flip up the black plastic retaining flap holding the white ribbon cable.
    • It's like popping open a coke can!
  10. Acer Swift 3 2022 Touchpad Replacement: passo 10, imagem 1 %32
    • Pull the ribbon cable out.
  11. Acer Swift 3 2022 Touchpad Replacement: passo 11, imagem 1 %32 Acer Swift 3 2022 Touchpad Replacement: passo 11, imagem 2 %32
    • Pull the black flap of film up to identify the two screws.
    • Remove the two 2 mm screws using a JIS #1 screwdriver.
  12. Acer Swift 3 2022 Touchpad Replacement: passo 12, imagem 1 %32
    • Take out the touchpad.
Conclusão
Anna Miller
Membro desde: 09/26/22
888 Reputação
Autoria de 6 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 50
Ao todo: 1,239
