Ir para o conteúdo principal
Acer Spin 3 SP315-51-757C Battery Replacement
O que você precisa
  1. Acer Spin 3 SP315-51-757C Battery Replacement, Back Panel: passo 1, imagem 1 %32 Acer Spin 3 SP315-51-757C Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Battery Replacement: passo 2, imagem 1 %32 Acer Spin 3 SP315-51-757C Battery Replacement: passo 2, imagem 2 %32 Acer Spin 3 SP315-51-757C Battery Replacement: passo 2, imagem 3 %32
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Battery Replacement: passo 3, imagem 1 %32
    • Lift the back panel off of the laptop.
  4. Acer Spin 3 SP315-51-757C Battery Replacement, Battery: passo 4, imagem 1 %32 Acer Spin 3 SP315-51-757C Battery Replacement, Battery: passo 4, imagem 2 %32
    • Remove the two Phillips #0 screws holding the battery inside the laptop case.
  5. Acer Spin 3 SP315-51-757C Battery Replacement: passo 5, imagem 1 %32 Acer Spin 3 SP315-51-757C Battery Replacement: passo 5, imagem 2 %32 Acer Spin 3 SP315-51-757C Battery Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using either your hands or a pair of tweezers, carefully pull the battery's cable out of its motherboard port.
  6. Acer Spin 3 SP315-51-757C Battery Replacement: passo 6, imagem 1 %32
    • Using your hands, lift up on the battery from its slot, and carefully slide it away from you before fully lifting it out of the case.
Conclusão
3 outras pessoas executaram este guia.
3 comentários
Wasted $50 on a battery that doesn’t work. I’m still trying to find why my Acer 2 in 1 will no longer turn on.
E L - Responder
That is a bummer, and something that concerns me as well. I’d like to replace the battery but it’s so common to get a failed battery or one that fails in a short period of time. Recently I’ve purchased two consecutive bad lithium drill batteries from ebay. Hope you get your computer figured out.
Adam Kahler -
I believe this guide would apply to most or all of the SP315-51-XXX laptops. I have a -79NT and the process and internals look the same.
Adam Kahler - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 27
Últimos 30 dias: 68
Ao todo: 4,298
