Introdução
This guide will provide step by step instructions on how to replace the screen on an Acer Iconia Tab A500.
O que você precisa
Remove the 5mm screws that are securing the battery to the rest of the tablet.
Use the Phillips #00 Screwdriver to remove the 5mm screws.
Locate the 4 screws and cable that hold in the two speakers.
Use the Phillips #1 screwdriver to remove these 2mm black screws.
Remove the 2mm silver screws.
Using the Phillips #1 screwdriver, remove the screws near the edges of the tablet.
Remove this components near the edge of the tablet by unscrewing the 5mm screw holding the top in place.
7 outras pessoas executaram este guia.
