Ir para o conteúdo principal
Acer Iconia One 7 Battery Replacement
O que você precisa
    1. Acer Iconia One 7 Battery Replacement, Battery: passo 1, imagem 1 %32
      • Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
      Pergunte ao FixBot
      Comentar
    2. Acer Iconia One 7 Battery Replacement: passo 2, imagem 1 %32
      • Using a plastic opening tool, separate the back cover from the main device.
      • Open each side continuously to ensure all sides have been separated.
      Pergunte ao FixBot
      Comentar
    3. Acer Iconia One 7 Battery Replacement: passo 3, imagem 1 %32
      • Turn the tablet over so the battery is facing up.
      Pergunte ao FixBot
      Comentar
    4. Acer Iconia One 7 Battery Replacement: passo 4, imagem 1 %32 Acer Iconia One 7 Battery Replacement: passo 4, imagem 2 %32
      • Carefully pull back the black tape covering the battery lead connector.
      • Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    5. Acer Iconia One 7 Battery Replacement: passo 5, imagem 1 %32 Acer Iconia One 7 Battery Replacement: passo 5, imagem 2 %32 Acer Iconia One 7 Battery Replacement: passo 5, imagem 3 %32
      Ferramenta utilizada neste passo:
      Plastic Cards
      $2.99
      • Using a plastic card or opening pick, separate the battery from the rest of the device.
      • Do not use a metal spudger like seen in the example photos. Use a plastic card to avoid bending or rupturing the battery.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 8-5, Eyestone Fall 2015 Membro de USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Membros
Autoria de 5 guias
4Comentários do guia
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
Stanley So - Responder Compartilhar
Thank you for this guide, replaced my battery (very easy with guide) and now my tablet works good. Also saved me some money. Thanks
vlamar14 - Responder Compartilhar
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
wantalktasol - Responder Compartilhar
Where I can order the new battery part?
melanieloa3 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 15
Últimos 30 dias: 48
Ao todo: 19,133
