Ir para o conteúdo principal
Acer Chromebook CB3-532-C47C Touchpad Replacement
O que você precisa
  1. Acer Chromebook CB3-532-C47C Touchpad Replacement, Back Panel: passo 1, imagem 1 %32 Acer Chromebook CB3-532-C47C Touchpad Replacement, Back Panel: passo 1, imagem 2 %32
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 2, imagem 1 %32 Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Touchpad Replacement, Remove the battery cable: passo 3, imagem 1 %32
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Touchpad Replacement, Battery: passo 4, imagem 1 %32 Acer Chromebook CB3-532-C47C Touchpad Replacement, Battery: passo 4, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
  5. Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 5, imagem 1 %32
    • Remove the battery from the laptop.
  6. Acer Chromebook CB3-532-C47C Touchpad Replacement, Touchpad: passo 6, imagem 1 %32 Acer Chromebook CB3-532-C47C Touchpad Replacement, Touchpad: passo 6, imagem 2 %32
    • Flip up the retaining latch securing the touchpad cable to the motherboard.
  7. Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 7, imagem 1 %32
    • Pull the ribbon from the motherboard laterally off the touchpad.
  8. Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 8, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the three 3.2 mm screws holding the touchpad to the laptop.
  9. Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 9, imagem 1 %32 Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 9, imagem 2 %32 Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 9, imagem 3 %32
    • Carefully lift up on the keyboard ribbon cable and the insulating sheet immediately below it so the touchpad can clear them.
    • Lift the touchpad slightly from the top.
    • Pull the touchpad toward the motherboard as you continue to lift it, sliding it out from under the retaining fingers at the bottom.
  10. Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 10, imagem 1 %32 Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 10, imagem 2 %32 Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 10, imagem 3 %32
    • Remove the touchpad.
    • When reinstalling:
    • Make sure the touchpad goes underneath the two retaining fingers when reinstalling it.
    • The touchpad is correctly aligned when the guide pins next to the left and right screws are inserted in the holes.
Conclusão
Sadie Brown
Membro desde: 10/25/21
967 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 3-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 239
