Ir para o conteúdo principal
Acer Chromebook CB3-532-C47C Motherboard Replacement
O que você precisa
  1. Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: passo 1, imagem 2 %32
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Motherboard Replacement: passo 2, imagem 1 %32 Acer Chromebook CB3-532-C47C Motherboard Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove the battery cable: passo 3, imagem 1 %32
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: passo 4, imagem 1 %32 Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: passo 4, imagem 2 %32
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: passo 5, imagem 1 %32 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: passo 5, imagem 2 %32 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: passo 5, imagem 3 %32
    • Using the Phillips #0 screwdriver, remove the single 6 mm screw securing the Wi-Fi card.
    • Pull the Wi-Fi card straight out of the motherboard and remove it from the device.
  6. Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: passo 6, imagem 1 %32 Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: passo 6, imagem 2 %32
    • Pull the black ribbon attached to the speakers out of the motherboard.
  7. Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: passo 7, imagem 1 %32 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: passo 7, imagem 2 %32 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: passo 7, imagem 3 %32
    • Peel the yellow tape off the black keyboard ribbon cable on the motherboard.
    • Use a spudger to slide the black tabs on either side of the connector forward slightly.
    • Pull the black ribbon straight towards you to remove it from the motherboard.
  8. Acer Chromebook CB3-532-C47C Motherboard Replacement: passo 8, imagem 1 %32 Acer Chromebook CB3-532-C47C Motherboard Replacement: passo 8, imagem 2 %32 Acer Chromebook CB3-532-C47C Motherboard Replacement: passo 8, imagem 3 %32
    • Flip up the tabs over the two white ribbons on the left using your finger.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Pull the ribbons out of the motherboard by the blue tabs.
  9. Acer Chromebook CB3-532-C47C Motherboard Replacement: passo 9, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove four 6 mm screws.
    • Using the same Phillips #1 screwdriver, remove five 3 mm screws securing the metal plate to the motherboard.
  10. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove Motherboard: passo 10, imagem 1 %32
    • Remove the metal plate over the motherboard.
    • Remove the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Sadie Brown
Membro desde: 10/25/21
967 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 3-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Duração total: 622
