Ir para o conteúdo principal
Acer Chromebook CB3-532-C47C Keyboard Keys Replacement
O que você precisa
  1. Acer Chromebook CB3-532-C47C Keyboard Keys Replacement, Keyboard Keys: passo 1, imagem 1 %32
    • Place the plastic opening tool directly underneath the key and pry upwards to remove the key.
    • Do not use too much force to avoid separating the retainer clip on the keyboard.
  2. Acer Chromebook CB3-532-C47C Keyboard Keys Replacement: passo 2, imagem 1 %32
    • Repeat with each key that needs to be removed.
    • If you are removing the keys in order to clean the keyboard, please refer to the troubleshooting guide to complete this process.
Conclusão
To reassemble your device, press the keys back onto the keyboard so that the figures are facing you.
Sadie Brown
Membro desde: 10/25/21
967 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 3-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 18
Duração total: 278
