Ir para o conteúdo principal
Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement
O que você precisa
  1. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: passo 1, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: passo 1, imagem 2 %32 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: passo 2, imagem 1 %32
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: passo 3, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: passo 3, imagem 2 %32
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: passo 4, imagem 1 %32
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: passo 5, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: passo 5, imagem 2 %32 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: passo 5, imagem 3 %32
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: passo 6, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: passo 6, imagem 2 %32
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: passo 7, imagem 1 %32
    • Lift the battery out gently.
  8. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Trackpad: passo 8, imagem 1 %32
    • Remove the strip of tape that secures the motherboard connector to the track pad.
  9. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: passo 9, imagem 1 %32
    • Unclip the motherboard connector from the track pad.
  10. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: passo 10, imagem 1 %32
    • Remove the strip of electrical tape from across the top of the track pad.
  11. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: passo 11, imagem 1 %32
    • Remove three 4 mm JIS #0 screws from the top of the track pad.
  12. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: passo 12, imagem 1 %32
    • Lift the laptop base and the track pad will come out from the front of the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 29
Duração total: 961
