Ir para o conteúdo principal
Acer Chromebook 14 CB3-431-C3WS Screen Replacement
O que você precisa
  1. Acer Chromebook 14 CB3-431-C3WS Screen Replacement, Screen: passo 1, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Screen Replacement, Screen: passo 1, imagem 2 %32
    • Using an iFixit opening pick, pop off the bezel from around the screen, beginning on one side and continuing around the whole screen.
    • Remove the barrier from the front of the screen.
  2. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: passo 2, imagem 1 %32
    • Starting in the top right of the screen, remove the six 4mm JIS #0 screws that secure the computer screen to the top.
    • There will be two sets of two screws on the top, one screw on each side of the bottom of the screen.
  3. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: passo 3, imagem 1 %32
    • Pull the screen down, and lay it flat against the keyboard.
  4. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: passo 4, imagem 1 %32
    • Disconnect the input connector from the screen.
  5. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: passo 5, imagem 1 %32
    • Remove the screen.
Conclusão
3 comentários
I have horizontal lines that appear for a split second on my screen at random times . Pushing the screen makes the lines appear also. I think I might have dropped my laptop , which may have caused this. Would changing the screen fix this?
aarondhesi - Responder
Hi, i have the same problem. did it work for you?
Another Backup -
It should! When we looked into troubleshooting this, changing the screen can help with the lines you're seeing.
Samantha Postma - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 37
Duração total: 3,437
