Introdução
One of the most common complaints about the Acer Chromebook 14 CB3-431-C3WS is that it has a short life span. This can be due to a few reasons, one being that the motherboard may have gone out. A common misconception is that once the motherboard goes out, the entire Acer Chromebook needs to be replaced. Following the steps in this guide may not only save you money on replacing your whole laptop but will also help save the planet from additional technology waste.
Before attempting to replace your motherboard, check the troubleshooting guide to see if there may be an easier solution.
Make sure the laptop is powered off and disconnected from any external power source before beginning any repairs.
O que você precisa
Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
Disconnect the LCD cable from the motherboard by removing the tape on the LCD connector, then gently pulling out the ribbon cable.
3 outras pessoas executaram este guia.
