Ir para o conteúdo principal
Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement
O que você precisa
  1. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: passo 1, imagem 2 %32 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 3, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 3, imagem 2 %32
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 4, imagem 1 %32
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: passo 5, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: passo 5, imagem 2 %32 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: passo 5, imagem 3 %32
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 6, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 6, imagem 2 %32
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 7, imagem 1 %32
    • Lift the battery out gently.
  8. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Disconnect the LCD cable from the motherboard by removing the tape on the LCD connector, then gently pulling out the ribbon cable.
  9. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 9, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 9, imagem 2 %32 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 9, imagem 3 %32
    • Disconnect the LCD cable from the motherboard by gently pulling on the cable.
  10. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 10, imagem 1 %32
    • Disconnect the trackpad by pulling on the trackpad connector cable.
  11. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 11, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 11, imagem 2 %32
    • Disconnect the daughterboard from the motherboard by gently removing the daughterboard cable from the motherboard connector.
  12. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 12, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 12, imagem 2 %32
    • Remove the electrical tape covering the screw that holds the Wi-Fi card in place.
    • Remove the single 4mm JIS #0 screw that holds the Wi-Fi card in place.
  13. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 13, imagem 1 %32
    • Remove the seven 4mm JIS #0 screws that hold the motherboard in place.
  14. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: passo 14, imagem 1 %32
    • Gently remove the motherboard.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 53
Duração total: 1,626
