Ir para o conteúdo principal
Acer Chromebook 14 CB3-431-C3WS Battery Replacement
O que você precisa
  1. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: passo 1, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: passo 1, imagem 2 %32 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 2, imagem 1 %32
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 3, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 3, imagem 2 %32
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 4, imagem 1 %32
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: passo 5, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: passo 5, imagem 2 %32 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: passo 5, imagem 3 %32
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 6, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 6, imagem 2 %32
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 7, imagem 1 %32
    • Lift the battery out gently.
Conclusão
8 outras pessoas executaram este guia.
3 comentários
Bonjour vous vendez les batteries CB3-431
mercier-nicolas - Responder
Vous vendez les batteries CB3-431
Instructions were great. Battery installation complete! I was very glad to find step by step instructions instead of a video. The Chromebook powered up successfully. Now waiting for it to charge. Thank you!
Sherry Chase - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 34
Duração total: 5,456
