Introdução
In this guide you will learn how to disassemble your laptop, remove the battery and replace it.
O que você precisa
First you will flip your laptop upside down so the battery side is facing up.
3 outras pessoas executaram este guia.
2 comentários
Yes don’t need to take cover off -battery can be removed by using a pen/screwdriver to slide the tab to the side & battery releases.
It has a very small image of an arrow with a pen next to it. Very misleading (I tried to push it in first!)
If you wiggle the battery, you can see the battery release tab moves with it :-)
