Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
Carefully remove the back cover using the opening tool.
Remove the yellow tape from the circuit board that is connected to the USB port.
Carefully unplug the two bundled cable connectors by pulling on them.
Flip up the ZIF connector that holds the larger ribbon cable in place with the opening tool.
Carefully unplug the larger ribbon cable by pulling on its blue tab.
Flip up the small ZIF connector that holds the smaller ribbon cable in place with the opening tool.
Carefully unplug the smaller ribbon cable by pulling on its blue tab.
Lift the security tab so that it will be out of the way when you remove the circuit board.
Remove the circuit board by lifting it up with the opening tool.
