Ir para o conteúdo principal
Acer Aspire R7 Wi-Fi Card Replacement
O que você precisa
  1. Acer Aspire R7 Wi-Fi Card Replacement, Cover: passo 1, imagem 1 %32
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
    Use the blue plastic opening tool to carefully remove the rubber pad which covers the one remaining screw.
    Picture shows the rubber pad removed but srew to be removed is not indicated
    Anthymoine - Responder
  2. Acer Aspire R7 Wi-Fi Card Replacement: passo 2, imagem 1 %32 Acer Aspire R7 Wi-Fi Card Replacement: passo 2, imagem 2 %32 Acer Aspire R7 Wi-Fi Card Replacement: passo 2, imagem 3 %32
    • Remove six 6mm T7 screws.
    • Remove four 4mm T7 screws.
    • Remove two 10mm T7 screws
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining two10mm T7 screws.
    Step 2 is missing the 1 (10mm T-7 ) screw that is under a rubber pad in the bottom middle of the laptop. The picture shows this pad and screw already missing. Note the silver color instead of the black color of the rest of the bottom of the laptop.
    Daniel Flynn - Responder
  3. Acer Aspire R7 Wi-Fi Card Replacement: passo 3, imagem 1 %32
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Wi-Fi Card Replacement, Wi-Fi Card: passo 4, imagem 1 %32 Acer Aspire R7 Wi-Fi Card Replacement, Wi-Fi Card: passo 4, imagem 2 %32
    • Locate the WiFi Card antenna wires
    • Remove both antenna wires from the WiFi card by prying upwards with the spudger tool
  5. Acer Aspire R7 Wi-Fi Card Replacement: passo 5, imagem 1 %32
    • Remove the (1) 3.5mm #00 Phillips retaining screw
    • Once the screw is removed, the spring loaded hinge will tilt the WiFi card up
  6. Acer Aspire R7 Wi-Fi Card Replacement: passo 6, imagem 1 %32
    • With the retaining screw removed, pull the WiFi card out of the socket
Conclusão
Andrew Rodiek
Membro desde: 01/13/15
601 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 3-4, Hickman Winter 2015 Membro de USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Membros
Autoria de 7 guias
2 comentários
The factory wi fi card is so weak. Is there a better wi fi card to buy and put in? 952-454-1659 Thank you
John - Responder
This answer might be useful for others who still want to update their Wifi card in their R7-572.
I just replaced the original Broadcom BCM943228HMB on my R7-572 with an Intel 7260HMW CN: 08TF1D (Standard half-height mini PCI-e interface card ). I found it on ebay:https://www.ebay.ca/itm/4-0-Wireless-Min... (19 USD as of October 2018)
After the card is installed, run Intel Driver & Support Assistant and my driver where updated to the latest ones (for both the AC 7260 and the Bluetooth adapter). http://www.intel.com/content/www/us/en/s...
I am using Windows 8.1 on this laptop.
HTH
Michael Cantinotti - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 27
Ao todo: 4,142
