Ir para o conteúdo principal
Acer Aspire R5-571T-57Z0 Display Assembly Replacement
O que você precisa
  1. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Battery: passo 1, imagem 2 %32
    • Remove the three 4.0 mm screws from the battery using a Phillips #00 screwdriver.
    • Unplug the cable connected to the RAM.
    • Carefully remove the battery.
  2. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Display Assembly: passo 2, imagem 1 %32 Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Display Assembly: passo 2, imagem 2 %32
    • Remove the six 4.0 mm screws from the hinges using a Phillips #00 screwdriver.
  3. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: passo 3, imagem 1 %32 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: passo 3, imagem 2 %32
    • Peel back the stickers from the display cable.
  4. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: passo 4, imagem 1 %32 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: passo 4, imagem 2 %32 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: passo 4, imagem 3 %32
    • Hold back the film protecting the Wi-Fi card.
    • Disconnect the touch screen cable.
  5. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: passo 5, imagem 1 %32 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: passo 5, imagem 2 %32
    • Pull back the tape covering the connectors.
    • Detach the two connectors (one black wire, one white wire).
  6. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: passo 6, imagem 1 %32 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: passo 6, imagem 2 %32
    • Disconnect the touch control cable next to the black film.
  7. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: passo 7, imagem 1 %32 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: passo 7, imagem 2 %32
    • Flip over the laptop and pull back to remove the display assembly.
Conclusão
Kevin Chen
Membro desde: 03/23/22
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 341
