Ir para o conteúdo principal
Acer Aspire 5742G Memory stick Replacement
O que você precisa
Vídeo de Apresentação
click here for video
  1. Acer Aspire 5742G Memory stick Replacement, Memory stick: passo 1, imagem 1 %32
    • Make sure your computer is off and remove the battery with the security tabs shown in the picture
  2. Acer Aspire 5742G Memory stick Replacement: passo 2, imagem 1 %32
    • Remove these philips screws, only two :)
  3. Acer Aspire 5742G Memory stick Replacement: passo 3, imagem 1 %32 Acer Aspire 5742G Memory stick Replacement: passo 3, imagem 2 %32
    • Then from the dented tab, either your finger, card or spudger will work, and start prying GENTLY!
    • Easily work your way around.
    • WARNING! PLASTIC TABS! be careful not to break them!
  4. Acer Aspire 5742G Memory stick Replacement: passo 4, imagem 1 %32
    • Now you've removed the cover, you will get access to your Antenna, HDD, and RAM
    • Please remove both tabs with the memory stick at the same time
  5. Acer Aspire 5742G Memory stick Replacement: passo 5, imagem 1 %32
    • Now put the new memory stick in!
    • When it is in, then gently push it downwards to lock it in place!
    • Be aware you have to line up the stick with a pin in the socket!!
Conclusão
Petter Berget
Membro desde: 05/12/15
767 Reputação
Autoria de 3 guias
Equipe
Kid fixers Membro de Kid fixers
Community
186 Membros
Autoria de 256 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 19
Ao todo: 871
