Ir para o conteúdo principal
Acer Aspire 5253 RAM Replacement
O que você precisa
  1. Acer Aspire 5253 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over.
    Pergunte ao FixBot
    Comentar
  2. Acer Aspire 5253 RAM Replacement: passo 2, imagem 1 %32
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
    Pergunte ao FixBot
    Comentar
  3. Acer Aspire 5253 RAM Replacement: passo 3, imagem 1 %32
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
    Pergunte ao FixBot
    Comentar
  4. Acer Aspire 5253 RAM Replacement: passo 4, imagem 1 %32
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
    Pergunte ao FixBot
    Comentar
  5. Acer Aspire 5253 RAM Replacement: passo 5, imagem 1 %32
    • You have successfully removed the battery. Congratulations!
    Pergunte ao FixBot
    Comentar
  6. Acer Aspire 5253 RAM Replacement, Back Cover Panel: passo 6, imagem 1 %32
    • Now, locate the two screws that hold the back cover panel onto the laptop.
    Pergunte ao FixBot
    Comentar
  7. Acer Aspire 5253 RAM Replacement: passo 7, imagem 1 %32
    • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • The screws are 3/8" in length and have a 1/4" head.
    Pergunte ao FixBot
    Comentar
  8. Acer Aspire 5253 RAM Replacement: passo 8, imagem 1 %32 Acer Aspire 5253 RAM Replacement: passo 8, imagem 2 %32
    • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
    Pergunte ao FixBot
    Comentar
  9. Acer Aspire 5253 RAM Replacement: passo 9, imagem 1 %32
    • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
    Pergunte ao FixBot
    Comentar
  10. Acer Aspire 5253 RAM Replacement, RAM: passo 10, imagem 1 %32
    • Now, locate the RAM.
    Pergunte ao FixBot
    Comentar
  11. Acer Aspire 5253 RAM Replacement: passo 11, imagem 1 %32
    • Locate the two metal pieces on both sides of the RAM that are holding it in place.
    Pergunte ao FixBot
    Comentar
  12. Acer Aspire 5253 RAM Replacement: passo 12, imagem 1 %32
    • Pull the tabs apart to remove the RAM.
    • The RAM will pop up once they are pried open.
    Pergunte ao FixBot
    Comentar
  13. Acer Aspire 5253 RAM Replacement: passo 13, imagem 1 %32 Acer Aspire 5253 RAM Replacement: passo 13, imagem 2 %32
    • Carefully slide the RAM out of the compartment.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Cynthia Barajas
Membro desde: 04/08/14
2.258 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 8-11, Regan Spring 2014 Membro de Cal Poly, Team 8-11, Regan Spring 2014
CPSU-REGAN-S14S8G11
4 Membros
Autoria de 15 guias
1Comentário do guia
which bus-ram acer 5253 can use? i know it use bus 1066 but i don't know with bus 1666 how is machine active?
nhanblack1996 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 50
Ao todo: 4,524
