Ir para o conteúdo principal
Acer Aspire 5253 Keyboard Replacement
O que você precisa
  1. Acer Aspire 5253 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over.
    Pergunte ao FixBot
    Comentar
  2. Acer Aspire 5253 Keyboard Replacement: passo 2, imagem 1 %32
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
    Pergunte ao FixBot
    Comentar
  3. Acer Aspire 5253 Keyboard Replacement: passo 3, imagem 1 %32
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
    Pergunte ao FixBot
    Comentar
  4. Acer Aspire 5253 Keyboard Replacement: passo 4, imagem 1 %32
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
    Pergunte ao FixBot
    Comentar
  5. Acer Aspire 5253 Keyboard Replacement: passo 5, imagem 1 %32
    • You have successfully removed the battery. Congratulations!
    Pergunte ao FixBot
    Comentar
  6. Acer Aspire 5253 Keyboard Replacement, Keyboard: passo 6, imagem 1 %32
    • Fling your laptop over and open it as shown in the image.
    Pergunte ao FixBot
    Comentar
  7. Acer Aspire 5253 Keyboard Replacement: passo 7, imagem 1 %32
    • Locate the tabs keeping the keyboard in place.
    Pergunte ao FixBot
    Comentar
  8. Acer Aspire 5253 Keyboard Replacement: passo 8, imagem 1 %32 Acer Aspire 5253 Keyboard Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using thin tweezers push the tabs in the keyboard in and pull up on the edge of the keyboard.
    • The keyboard will bend and it will seem like its breaking, but don't worry this is OK!
    Pergunte ao FixBot
    Comentar
  9. Acer Aspire 5253 Keyboard Replacement: passo 9, imagem 1 %32
    • Once the keyboard begins popping out of place use your hand to keep the part that has been detached from the laptop in the air.
    • Continue pushing in tabs and lifting up the keyboard as described above.
    Pergunte ao FixBot
    Comentar
  10. Acer Aspire 5253 Keyboard Replacement: passo 10, imagem 1 %32
    • Once the keyboard has been separated from the body of the laptop carefully lift the keyboard up and tilt it forward, leaving it to rest on the laptop as shown.
    • Do not pull the keyboard up with too much force because you may cause damage to your laptop!
    Pergunte ao FixBot
    Comentar
  11. Acer Aspire 5253 Keyboard Replacement: passo 11, imagem 1 %32 Acer Aspire 5253 Keyboard Replacement: passo 11, imagem 2 %32
    • Using tweezers pull the white tab down on both sides. This will release the blue and black connector.
    Pergunte ao FixBot
    Comentar
  12. Acer Aspire 5253 Keyboard Replacement: passo 12, imagem 1 %32
    • Pull the blue and black connector out of its socket.
    • Make sure it comes off easily or you may rip it.
    Pergunte ao FixBot
    Comentar
  13. Acer Aspire 5253 Keyboard Replacement: passo 13, imagem 1 %32
    • Now you can pull the keyboard away from the laptop.
    Pergunte ao FixBot
    Comentar
Conclusão
11 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 8-11, Regan Spring 2014 Membro de Cal Poly, Team 8-11, Regan Spring 2014
CPSU-REGAN-S14S8G11
4 Membros
Autoria de 15 guias
3Comentários do guia
I'm probably going to have to replace my 5253 keyboard, and this guide is head and shoulders above anything else I've seen. However, I'm stuck on step 8.
It says "push the tabs ... in". Is that "in", meaning "away from the keyboard back into the chassis"?
Then, "pull up on the edge of the keyboard". Do I pull up with the tweezers somehow?
On what? The photo on step 8 shows working on the middle tab. Presumably the tabs closer to the left corner have already been pushed in? I'm not getting past that first tab on the top-left.
Any help would be very much appreciated. Thank you.
Tom Asbury - Responder Compartilhar
Gently pull the small white bar that holds the wires in place that hold the keyboard towards you one side at a time so you don’t break the wires accidentally! Be very careful when moving the small white bar so you don’t break the wires that connect to the keyboard! It is not difficult at all! It only takes about 10-12 second to move the small white bar towards you! When you can’t move the small white bar any further towards you then you know it’s safe to remove the keyboard!
Hector E - Responder Compartilhar
Thanks….this guide was really helpful for me to change my key board
John H 10 -25-2017
j_ohn3150 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 80
Ao todo: 14,837
