Ir para o conteúdo principal
Acer Aspire 3000 RAM Replacement
O que você precisa
  1. Acer Aspire 3000 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
    Pergunte ao FixBot
    Comentar
  2. Acer Aspire 3000 RAM Replacement: passo 2, imagem 1 %32 Acer Aspire 3000 RAM Replacement: passo 2, imagem 2 %32
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
    Pergunte ao FixBot
    Comentar
  3. Acer Aspire 3000 RAM Replacement: passo 3, imagem 1 %32 Acer Aspire 3000 RAM Replacement: passo 3, imagem 2 %32
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
    Pergunte ao FixBot
    Comentar
  4. Acer Aspire 3000 RAM Replacement, RAM: passo 4, imagem 1 %32
    • Unscrew the two 4.6 mm Phillips #1 screws found at the bottom of the RAM cover using the phillips head j1 bit.
    Pergunte ao FixBot
    Comentar
  5. Acer Aspire 3000 RAM Replacement: passo 5, imagem 1 %32
    • Open the RAM cover by wedging the opening tool and the metal spudger in the opening between the two screws.
    Pergunte ao FixBot
    Comentar
  6. Acer Aspire 3000 RAM Replacement: passo 6, imagem 1 %32
    • Slide the opening tool around the sides of the cover to release the 3 tabs that hold the cover down.
    Pergunte ao FixBot
    Comentar
  7. Acer Aspire 3000 RAM Replacement: passo 7, imagem 1 %32
    • Lift and pull the cover back towards you to detach it from the device.
    Pergunte ao FixBot
    Comentar
  8. Acer Aspire 3000 RAM Replacement: passo 8, imagem 1 %32
    • Push the white tabs on either side away from the from the chip.
    • The chip should be released upward automatically after pushing the tabs.
    Pergunte ao FixBot
    Comentar
  9. Acer Aspire 3000 RAM Replacement: passo 9, imagem 1 %32
    • Pull and lift the chip to release it from the RAM port.
    Pergunte ao FixBot
    Comentar
  10. Acer Aspire 3000 RAM Replacement: passo 10, imagem 1 %32
    • Repeat step 9 to release the bottom chip from its RAM port.
    Pergunte ao FixBot
    Comentar
Conclusão
roro6730
Membro desde: 10/30/16
351 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 4-2, Williams Fall 2016 Membro de Baylor, Team 4-2, Williams Fall 2016
BU-WILLIAMS-F16S4G2
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 32
Ao todo: 1,105
