Ir para o conteúdo principal
Acer AL1916 Motherboard Replacement
O que você precisa
    1. Acer AL1916 Motherboard Replacement, Stand: passo 1, imagem 1 %32
      • Lay the monitor on a flat surface so that the back is facing up.
      Pergunte ao FixBot
      Comentar
    2. Acer AL1916 Motherboard Replacement: passo 2, imagem 1 %32 Acer AL1916 Motherboard Replacement: passo 2, imagem 2 %32
      • Grab the hinge cover with both hands on either side of the stand.
      • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
      Pergunte ao FixBot
      Comentar
    3. Acer AL1916 Motherboard Replacement: passo 3, imagem 1 %32 Acer AL1916 Motherboard Replacement: passo 3, imagem 2 %32
      • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
      • Support the monitor while removing the screws to prevent the monitor from falling.
      • Lift up to detach the stand.
      Pergunte ao FixBot
      Comentar
    1. Acer AL1916 Motherboard Replacement, Outer Case: passo 4, imagem 1 %32 Acer AL1916 Motherboard Replacement, Outer Case: passo 4, imagem 2 %32
      • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
      Pergunte ao FixBot
      Comentar
    2. Acer AL1916 Motherboard Replacement: passo 5, imagem 1 %32 Acer AL1916 Motherboard Replacement: passo 5, imagem 2 %32 Acer AL1916 Motherboard Replacement: passo 5, imagem 3 %32
      • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
      • Tilt the plastic opening tool up to separate the back cover from the display bezel.
      • Continue around the perimeter of the monitor until the display bezel comes off.
      • A reasonable amount of force is necessary to detach the back cover from the display bezel.
      Pergunte ao FixBot
      Comentar
    3. Acer AL1916 Motherboard Replacement: passo 6, imagem 1 %32 Acer AL1916 Motherboard Replacement: passo 6, imagem 2 %32
      • Reposition the monitor so that the back is facing up.
      • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
      • Lift the back cover up.
      Pergunte ao FixBot
      Comentar
    1. Acer AL1916 Motherboard Replacement, EMI Shield: passo 7, imagem 1 %32 Acer AL1916 Motherboard Replacement, EMI Shield: passo 7, imagem 2 %32
      • Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
      Pergunte ao FixBot
      Comentar
    2. Acer AL1916 Motherboard Replacement: passo 8, imagem 1 %32 Acer AL1916 Motherboard Replacement: passo 8, imagem 2 %32
      • Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input.
      Pergunte ao FixBot
      Comentar
    3. Acer AL1916 Motherboard Replacement: passo 9, imagem 1 %32 Acer AL1916 Motherboard Replacement: passo 9, imagem 2 %32 Acer AL1916 Motherboard Replacement: passo 9, imagem 3 %32
      • Grab the metal casing by the sides and slide it down towards the bottom of the monitor.
      • Lift up to remove the metal casing.
      • Beware, metal casing is sharp!
      Pergunte ao FixBot
      Comentar
    1. Acer AL1916 Motherboard Replacement, Motherboard: passo 10, imagem 1 %32 Acer AL1916 Motherboard Replacement, Motherboard: passo 10, imagem 2 %32
      • Remove the beige control cable to the left of the VGA input by pulling it up.
      Pergunte ao FixBot
      Comentar
    2. Acer AL1916 Motherboard Replacement: passo 11, imagem 1 %32 Acer AL1916 Motherboard Replacement: passo 11, imagem 2 %32
      • Remove the rainbow-colored power cable by pulling it straight up.
      Pergunte ao FixBot
      Comentar
    3. Acer AL1916 Motherboard Replacement: passo 12, imagem 1 %32 Acer AL1916 Motherboard Replacement: passo 12, imagem 2 %32
      • Remove the display cable located at the top of the motherboard by pulling it out towards the top of the monitor.
      Pergunte ao FixBot
      Comentar
    4. Acer AL1916 Motherboard Replacement: passo 13, imagem 1 %32 Acer AL1916 Motherboard Replacement: passo 13, imagem 2 %32 Acer AL1916 Motherboard Replacement: passo 13, imagem 3 %32
      • Remove the three 7.7 mm Phillips #2 screws from the motherboard, and take out the motherboard by lifting it up.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 20-26, Maness Fall 2011 Membro de Cal Poly, Team 20-26, Maness Fall 2011
CPSU-MANESS-F11S20G26
4 Membros
Autoria de 14 guias
3Comentários do guia
How does one know weather it's the Motherboard or the PSU? What should the PSU be outputting to check it first? Or any other ways to check it
Tyler Wight - Responder Compartilhar
there are a few things that can help diagnose whether it is the power supply or the circuit board but sometimes it can be both. One thing you can do is just knowing the conditions of the home, did you have some power outage, or blinking of lights during storms and things like that. If you don't have a battery backup sometimes surge protectors are not going to save a system from failure just from power blinking on and off. This can cause backfire like issues that can glitch out the control board or power supply or domino the both. If you see power and the light turns on but when you hit the buttons nothing happens that either means the circuit board is failed because it is unable to process commands, or the power supply is only providing enough power to turn on the circuit board but nothing else. If you can not get a light at all and have tried plugging it in and out over and over and nothing no lights or anything than it is a good bet the power board has failed. If you don'twant to pay repairs take best guess
jamhi - Responder Compartilhar
Very often, espacially if the PSU is som years old, the electrolyt capacitors will dry out.
You can see it when the surface has blown up and is rounded. Normally this capacitors are flat. If you see, that one or more of this capacitors is bended, than replace all with the same values (capacity and voltage).
Eugen Schöller - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 47
Ao todo: 8,742
