Ir para o conteúdo principal
Acer AL1916 Display Replacement
O que você precisa
    1. Acer AL1916 Display Replacement, Stand: passo 1, imagem 1 %32
      • Lay the monitor on a flat surface so that the back is facing up.
      Pergunte ao FixBot
      Comentar
    2. Acer AL1916 Display Replacement: passo 2, imagem 1 %32 Acer AL1916 Display Replacement: passo 2, imagem 2 %32
      • Grab the hinge cover with both hands on either side of the stand.
      • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
      Pergunte ao FixBot
      Comentar
    3. Acer AL1916 Display Replacement: passo 3, imagem 1 %32 Acer AL1916 Display Replacement: passo 3, imagem 2 %32
      • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
      • Support the monitor while removing the screws to prevent the monitor from falling.
      • Lift up to detach the stand.
      Pergunte ao FixBot
      Comentar
    1. Acer AL1916 Display Replacement, Outer Case: passo 4, imagem 1 %32 Acer AL1916 Display Replacement, Outer Case: passo 4, imagem 2 %32
      • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
      Pergunte ao FixBot
      Comentar
    2. Acer AL1916 Display Replacement: passo 5, imagem 1 %32 Acer AL1916 Display Replacement: passo 5, imagem 2 %32 Acer AL1916 Display Replacement: passo 5, imagem 3 %32
      • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
      • Tilt the plastic opening tool up to separate the back cover from the display bezel.
      • Continue around the perimeter of the monitor until the display bezel comes off.
      • A reasonable amount of force is necessary to detach the back cover from the display bezel.
      Pergunte ao FixBot
      Comentar
    3. Acer AL1916 Display Replacement: passo 6, imagem 1 %32 Acer AL1916 Display Replacement: passo 6, imagem 2 %32
      • Reposition the monitor so that the back is facing up.
      • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
      • Lift the back cover up.
      Pergunte ao FixBot
      Comentar
    1. Acer AL1916 Display Replacement, EMI Shield: passo 7, imagem 1 %32 Acer AL1916 Display Replacement, EMI Shield: passo 7, imagem 2 %32
      • Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
      Pergunte ao FixBot
      Comentar
    2. Acer AL1916 Display Replacement: passo 8, imagem 1 %32 Acer AL1916 Display Replacement: passo 8, imagem 2 %32
      • Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input.
      Pergunte ao FixBot
      Comentar
    3. Acer AL1916 Display Replacement: passo 9, imagem 1 %32 Acer AL1916 Display Replacement: passo 9, imagem 2 %32 Acer AL1916 Display Replacement: passo 9, imagem 3 %32
      • Grab the metal casing by the sides and slide it down towards the bottom of the monitor.
      • Lift up to remove the metal casing.
      • Beware, metal casing is sharp!
      Pergunte ao FixBot
      Comentar
    1. Acer AL1916 Display Replacement, Display: passo 10, imagem 1 %32 Acer AL1916 Display Replacement, Display: passo 10, imagem 2 %32
      • Remove the three gold 7.5 mm Phillips #2 screws and one silver 8.3 mm Phillips #2 screw from the power supply.
      Pergunte ao FixBot
      Comentar
    2. Acer AL1916 Display Replacement: passo 11, imagem 1 %32 Acer AL1916 Display Replacement: passo 11, imagem 2 %32 Acer AL1916 Display Replacement: passo 11, imagem 3 %32
      • Remove the two pieces of yellow tape on the left side of the power supply.
      Pergunte ao FixBot
      Comentar
    3. Acer AL1916 Display Replacement: passo 12, imagem 1 %32 Acer AL1916 Display Replacement: passo 12, imagem 2 %32
      • Remove the four little white clips located underneath the pieces of tape by lifting up on their left side.
      Pergunte ao FixBot
      Comentar
    4. Acer AL1916 Display Replacement: passo 13, imagem 1 %32 Acer AL1916 Display Replacement: passo 13, imagem 2 %32 Acer AL1916 Display Replacement: passo 13, imagem 3 %32
      • With the needle-nose pliers, remove the four display connectors by pulling directly left.
      Pergunte ao FixBot
      Comentar
    5. Acer AL1916 Display Replacement: passo 14, imagem 1 %32 Acer AL1916 Display Replacement: passo 14, imagem 2 %32 Acer AL1916 Display Replacement: passo 14, imagem 3 %32
      • Remove the display cable located at the top of the circuit board by pulling it out towards the top of the monitor.
      Pergunte ao FixBot
      Comentar
    6. Acer AL1916 Display Replacement: passo 15, imagem 1 %32 Acer AL1916 Display Replacement: passo 15, imagem 2 %32 Acer AL1916 Display Replacement: passo 15, imagem 3 %32
      • Turn the monitor on its side so that the power supply and circuit board are facing to the right
      • Remove the two 6.6 mm Phillips #2 screws located on both sides of the metal casing (four screws total).
      Pergunte ao FixBot
      Comentar
    7. Acer AL1916 Display Replacement: passo 16, imagem 1 %32 Acer AL1916 Display Replacement: passo 16, imagem 2 %32
      • Set the monitor back down so that the power supply and circuit board are facing you.
      • Feed all four of the connector wires down through the metal casing.
      Pergunte ao FixBot
      Comentar
    8. Acer AL1916 Display Replacement: passo 17, imagem 1 %32 Acer AL1916 Display Replacement: passo 17, imagem 2 %32 Acer AL1916 Display Replacement: passo 17, imagem 3 %32
      • Grab the sides of the metal casing and lift up.
      • Turn the display over to see the front; you are ready replace the broken display with a new one!
      Pergunte ao FixBot
      Comentar
Conclusão
7 outras pessoas executaram este guia.
Keith
Membro desde: 10/06/11
375 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 20-26, Maness Fall 2011 Membro de Cal Poly, Team 20-26, Maness Fall 2011
CPSU-MANESS-F11S20G26
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 43
Ao todo: 9,970
