Ir para o conteúdo principal
Acer AL1714 LCD Replacement
O que você precisa
    1. Acer AL1714 LCD Replacement, LCD: passo 1, imagem 1 %32 Acer AL1714 LCD Replacement, LCD: passo 1, imagem 2 %32
      • Turn the monitor facedown.
      • Unscrew the 5 screws holding the back cover on.
      • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
      Pergunte ao FixBot
      Comentar
    2. Acer AL1714 LCD Replacement: passo 2, imagem 1 %32 Acer AL1714 LCD Replacement: passo 2, imagem 2 %32 Acer AL1714 LCD Replacement: passo 2, imagem 3 %32
      • Take the edge tool or a metal ruler and insert it into the bezel.
      • Apply pressure and push down.
      • Do the same to the right side.
      • Once the side of the bezel facing you is decoupled, take the back cover and pry it loose.
      • (This will require some force, you will hear a loud popping/snapping noises)
      Pergunte ao FixBot
      Comentar
    3. Acer AL1714 LCD Replacement: passo 3, imagem 1 %32 Acer AL1714 LCD Replacement: passo 3, imagem 2 %32 Acer AL1714 LCD Replacement: passo 3, imagem 3 %32
      • Remove the Power Button Circuit Board Flat Flex Cable from the Power Supply board under the metal cover.
      • Pull the cord back and out of the way.
      • (It may be stuck down with adhesive)
      Pergunte ao FixBot
      Comentar
    4. Acer AL1714 LCD Replacement: passo 4, imagem 1 %32 Acer AL1714 LCD Replacement: passo 4, imagem 2 %32 Acer AL1714 LCD Replacement: passo 4, imagem 3 %32
      • Unscrew the cord anchors for the VGA port.
      • (Use needle nose pliers if they're too tight for removal by hand)
      Pergunte ao FixBot
      Comentar
    5. Acer AL1714 LCD Replacement: passo 5, imagem 1 %32 Acer AL1714 LCD Replacement: passo 5, imagem 2 %32
      • Turn the monitor around.
      • Unscrew the 1 screw holding the Flat Power Cable cover in place.
      • Lift up and remove the Flat Power Cable cover.
      • (Careful: it may be sharp)
      Pergunte ao FixBot
      Comentar
    6. Acer AL1714 LCD Replacement: passo 6, imagem 1 %32
      • Unscrew the 5 screws holding the metal cage on.
      Pergunte ao FixBot
      Comentar
    7. Acer AL1714 LCD Replacement: passo 7, imagem 1 %32 Acer AL1714 LCD Replacement: passo 7, imagem 2 %32
      • Lift up on the back of metal cage, slightly.
      • Pull the cage toward self.
      • (Must be careful to free cover of the VGA port and power supply input)
      Pergunte ao FixBot
      Comentar
    8. Acer AL1714 LCD Replacement: passo 8, imagem 1 %32 Acer AL1714 LCD Replacement: passo 8, imagem 2 %32 Acer AL1714 LCD Replacement: passo 8, imagem 3 %32
      • Lift up on the Flat Flex Cable holder tabs to release the cords.
      • Lift up on the Flat Flex Cables and bend them out of the working area.
      Pergunte ao FixBot
      Comentar
    9. Acer AL1714 LCD Replacement: passo 9, imagem 1 %32 Acer AL1714 LCD Replacement: passo 9, imagem 2 %32 Acer AL1714 LCD Replacement: passo 9, imagem 3 %32
      • Unplug the 4 backlight wires from their ports on the Power Supply board.
      • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling and pulling the wires out of place)
      Pergunte ao FixBot
      Comentar
    10. Acer AL1714 LCD Replacement: passo 10, imagem 1 %32
      • Unscrew the 5 screws holding the Power Supply and Video Display boards.
      Pergunte ao FixBot
      Comentar
    11. Acer AL1714 LCD Replacement: passo 11, imagem 1 %32 Acer AL1714 LCD Replacement: passo 11, imagem 2 %32
      • Lift and remove the joined Power Supply and Video Display boards.
      Pergunte ao FixBot
      Comentar
    12. Acer AL1714 LCD Replacement: passo 12, imagem 1 %32 Acer AL1714 LCD Replacement: passo 12, imagem 2 %32 Acer AL1714 LCD Replacement: passo 12, imagem 3 %32
      • Carefully detach the Power Supply and Video Display boards at the connector joint.
      • (This step is not necessary to replace the LCD Module. This step is only a safety precaution so as not to bend or break the Power Supply connector joint)
      Pergunte ao FixBot
      Comentar
    13. Acer AL1714 LCD Replacement: passo 13, imagem 1 %32
      • Remove the Flat Flex Cable from the Power Button Circuit board.
      Pergunte ao FixBot
      Comentar
    14. Acer AL1714 LCD Replacement: passo 14, imagem 1 %32 Acer AL1714 LCD Replacement: passo 14, imagem 2 %32 Acer AL1714 LCD Replacement: passo 14, imagem 3 %32
      • Grasp, lift, and remove the LCD Module from the front panel.
      Pergunte ao FixBot
      Comentar
    15. Acer AL1714 LCD Replacement: passo 15, imagem 1 %32
      • The final product with the LCD Module removed.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-3, Brown Fall 2014 Membro de USF Tampa, Team 1-3, Brown Fall 2014
USFT-BROWN-F14S1G3
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 83
Ao todo: 3,825
