Ir para o conteúdo principal
Accessing Nokia 3100b Vibrating Unit
O que você precisa
  1. Accessing Nokia 3100b Vibrating Unit, Battery: passo 1, imagem 1 %32
    • Make sure your phone is turned off.
    Pergunte ao FixBot
    Comentar
  2. Accessing Nokia 3100b Vibrating Unit: passo 2, imagem 1 %32
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
    Pergunte ao FixBot
    Comentar
  3. Accessing Nokia 3100b Vibrating Unit, SIM Card: passo 3, imagem 1 %32
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    Pergunte ao FixBot
    Comentar
  4. Accessing Nokia 3100b Vibrating Unit: passo 4, imagem 1 %32
    • Retrieve your SIM card.
    Pergunte ao FixBot
    Comentar
  5. Accessing Nokia 3100b Vibrating Unit, Vibrating Unit: passo 5, imagem 1 %32
    • Separate the front cover from the base of the phone.
    • Set the front cover, as indicated, aside.
    Pergunte ao FixBot
    Comentar
  6. Accessing Nokia 3100b Vibrating Unit: passo 6, imagem 1 %32
    • Remove the screws indicated using a T6 Torx screwdriver.
    • Remove them in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple).
    Pergunte ao FixBot
    Comentar
  7. Accessing Nokia 3100b Vibrating Unit: passo 7, imagem 1 %32
    • Separate the screen assembly from the base of the phone.
    • Set the screen assembly, as indicated, aside.
    Pergunte ao FixBot
    Comentar
  8. Accessing Nokia 3100b Vibrating Unit: passo 8, imagem 1 %32
    • The vibrating unit can now be accessed. Note its location in the phone.
    Pergunte ao FixBot
    Comentar
  9. Accessing Nokia 3100b Vibrating Unit: passo 9, imagem 1 %32
    • The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
    Pergunte ao FixBot
    Comentar
  10. Accessing Nokia 3100b Vibrating Unit: passo 10, imagem 1 %32
    • The vibrating unit is now removed.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 29-64, Johann Spring 2010 Membro de Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 34
Ao todo: 1,979
