Ir para o conteúdo principal
Accessing LCD Screen
O que você precisa
    1. Accessing LCD Screen, Front and Back Cover: passo 1, imagem 1 %32 Accessing LCD Screen, Front and Back Cover: passo 1, imagem 2 %32
      • Remove the following screws:
      • Two silver 3.15mm Phillips #00 screws on the right side of the camera
      • Two silver 2.08mm Phillips #00 screws on the left side of the camera
      Pergunte ao FixBot
      Comentar
    2. Accessing LCD Screen: passo 2, imagem 1 %32
      • Remove the two indicated screws on the bottom of the camera:
      • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
      • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
      Pergunte ao FixBot
      Comentar
    3. Accessing LCD Screen: passo 3, imagem 1 %32 Accessing LCD Screen: passo 3, imagem 2 %32
      • Carefully pull the back of casing away from the front.
      Pergunte ao FixBot
      Comentar
    4. Accessing LCD Screen: passo 4, imagem 1 %32 Accessing LCD Screen: passo 4, imagem 2 %32 Accessing LCD Screen: passo 4, imagem 3 %32
      • After removing the back cover, several things must be removed.
      • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
      Pergunte ao FixBot
      Comentar
    5. Accessing LCD Screen: passo 5, imagem 1 %32 Accessing LCD Screen: passo 5, imagem 2 %32
      • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
      Pergunte ao FixBot
      Comentar
    1. Accessing LCD Screen, LCD: passo 6, imagem 1 %32 Accessing LCD Screen, LCD: passo 6, imagem 2 %32
      • On the front of the camera, in battery case, remove screws indicated:
      • Two black 2.05mm Phillips #00 screws
      Pergunte ao FixBot
      Comentar
    2. Accessing LCD Screen: passo 7, imagem 1 %32 Accessing LCD Screen: passo 7, imagem 2 %32
      • Flip the camera over to the backside and remove screws indicated:
      • The screw circled in red is a longer black 3.00mm Phillips #00 screw
      • The screw circled in red is a shorter black 2.00mm Phillips #00 screw
      Pergunte ao FixBot
      Comentar
    3. Accessing LCD Screen: passo 8, imagem 1 %32
      • Pull the cover plate off for the two power cord jacks.
      Pergunte ao FixBot
      Comentar
    4. Accessing LCD Screen: passo 9, imagem 1 %32 Accessing LCD Screen: passo 9, imagem 2 %32 Accessing LCD Screen: passo 9, imagem 3 %32
      • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
      Pergunte ao FixBot
      Comentar
    5. Accessing LCD Screen: passo 10, imagem 1 %32
      • Remove the orange tape on top of the SD cardholder.
      Pergunte ao FixBot
      Comentar
    6. Accessing LCD Screen: passo 11, imagem 1 %32 Accessing LCD Screen: passo 11, imagem 2 %32 Accessing LCD Screen: passo 11, imagem 3 %32
      • Open the battery cover and lift plastic piece off.
      Pergunte ao FixBot
      Comentar
    7. Accessing LCD Screen: passo 12, imagem 1 %32
      • Remove tape on left side of camera.
      Pergunte ao FixBot
      Comentar
    8. Accessing LCD Screen: passo 13, imagem 1 %32
      • Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
      Pergunte ao FixBot
      Comentar
    9. Accessing LCD Screen: passo 14, imagem 1 %32
      • Remove top left LCD bracket.
      • This is a small piece, be careful not to lose it.
      Pergunte ao FixBot
      Comentar
    10. Accessing LCD Screen: passo 15, imagem 1 %32 Accessing LCD Screen: passo 15, imagem 2 %32
      • Push down bottom left LCD bracket to release the LCD from grip.
      Pergunte ao FixBot
      Comentar
    11. Accessing LCD Screen: passo 16, imagem 1 %32
      • Gently lift up LCD screen.
      Pergunte ao FixBot
      Comentar
    12. Accessing LCD Screen: passo 17, imagem 1 %32 Accessing LCD Screen: passo 17, imagem 2 %32 Accessing LCD Screen: passo 17, imagem 3 %32
      • Slowly pull LCD screen to the left to remove it from the other grips.
      • BEWARE: The LCD screen is attached to the logic board by two wires at the bottom.
      Pergunte ao FixBot
      Comentar
Conclusão
Bassem Tossoun
Membro desde: 01/21/11
201 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-29, Regan Winter 2011 Membro de Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Membros
Autoria de 60 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 24
Últimos 30 dias: 70
Ao todo: 1,637
