Introdução
Use this guide to replace the battery of your AYL SoundFit. If your device's battery won't hold a charge, replacing the battery may resolve the problem.
O que você precisa
Remove the four hex screws on the top of the device using a 2.5 hex screwdriver.
4Comentários do guia
Which battery is this, and what is the mAH?
3.7V 1500mAh, 5.55Wh
The charger works but it does not say chargeing
18650 battery
