Ir para o conteúdo principal
ATT Trek HD 9020A Screen Replacement
O que você precisa
    1. ATT Trek HD 9020A Screen Replacement, Back Cover: passo 1, imagem 1 %32
      • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
      Pergunte ao FixBot
      Comentar
    2. ATT Trek HD 9020A Screen Replacement: passo 2, imagem 1 %32
      • Pull the screen away from the back panel.
      Pergunte ao FixBot
      Comentar
    1. ATT Trek HD 9020A Screen Replacement, Battery: passo 3, imagem 1 %32 ATT Trek HD 9020A Screen Replacement, Battery: passo 3, imagem 2 %32
      • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
      Pergunte ao FixBot
      Comentar
    2. ATT Trek HD 9020A Screen Replacement: passo 4, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 4, imagem 2 %32
      • Use the plastic opening tool to disconnect the black battery connector.
      • Gently lift the battery out of the device.
      Pergunte ao FixBot
      Comentar
    1. ATT Trek HD 9020A Screen Replacement, Motherboard: passo 5, imagem 1 %32 ATT Trek HD 9020A Screen Replacement, Motherboard: passo 5, imagem 2 %32
      • Using a Phillips #00 screwdriver, remove the seven 1 mm screws on the green perimeter of the motherboard.
      Pergunte ao FixBot
      Comentar
    2. ATT Trek HD 9020A Screen Replacement: passo 6, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 6, imagem 2 %32
      • Use the plastic opening tool to disconnect the large gold strip underneath the metal plate from the motherboard.
      Pergunte ao FixBot
      Comentar
    3. ATT Trek HD 9020A Screen Replacement: passo 7, imagem 1 %32
      • Use the plastic opening tool to disconnect the front and back cameras from motherboard.
      Pergunte ao FixBot
      Comentar
    4. ATT Trek HD 9020A Screen Replacement: passo 8, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 8, imagem 2 %32
      Ferramenta utilizada neste passo:
      $3.99
      • Use angled tweezers to pry up the black tab.
      • Use the angled tweezers to pull out the gold connector.
      Pergunte ao FixBot
      Comentar
    5. ATT Trek HD 9020A Screen Replacement: passo 9, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 9, imagem 2 %32
      • Use the angled tweezers to disconnect the gold connector.
      Pergunte ao FixBot
      Comentar
    6. ATT Trek HD 9020A Screen Replacement: passo 10, imagem 1 %32
      • Use the plastic opening tool to disconnect the black connectors on each side of the motherboard.
      Pergunte ao FixBot
      Comentar
    7. ATT Trek HD 9020A Screen Replacement: passo 11, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 11, imagem 2 %32
      • Use the plastic opening tool to lift the motherboard out of place.
      Pergunte ao FixBot
      Comentar
    1. ATT Trek HD 9020A Screen Replacement, Front Camera: passo 12, imagem 1 %32 ATT Trek HD 9020A Screen Replacement, Front Camera: passo 12, imagem 2 %32
      $3.99
      Pergunte ao FixBot
      Comentar
    1. ATT Trek HD 9020A Screen Replacement, Screen: passo 13, imagem 1 %32 ATT Trek HD 9020A Screen Replacement, Screen: passo 13, imagem 2 %32 ATT Trek HD 9020A Screen Replacement, Screen: passo 13, imagem 3 %32
      • Use the Phillips #00 screwdriver to remove the six 3 mm screws holding the black plastic corner pieces in place.
      • Gently lift the black corner pieces out of the device.
      Pergunte ao FixBot
      Comentar
    2. ATT Trek HD 9020A Screen Replacement: passo 14, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 14, imagem 2 %32
      $3.99
      • Use the angled tweezers to remove the black cables on each side of the device from their groove.
      Pergunte ao FixBot
      Comentar
    3. ATT Trek HD 9020A Screen Replacement: passo 15, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 15, imagem 2 %32
      • Use the plastic opening tool to disconnect the black cable connectors from each side of the device.
      Pergunte ao FixBot
      Comentar
    4. ATT Trek HD 9020A Screen Replacement: passo 16, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 16, imagem 2 %32
      • Remove the remaining ten 3 mm Phillips #00 screws.
      Pergunte ao FixBot
      Comentar
    5. ATT Trek HD 9020A Screen Replacement: passo 17, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 17, imagem 2 %32
      • Use the plastic opening tool to disconnect the remaining three gold connectors at the bottom of the device.
      Pergunte ao FixBot
      Comentar
    6. ATT Trek HD 9020A Screen Replacement: passo 18, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 18, imagem 2 %32
      • Use the plastic opening tool to pry up the grey plastic panel.
      Pergunte ao FixBot
      Comentar
    7. ATT Trek HD 9020A Screen Replacement: passo 19, imagem 1 %32 ATT Trek HD 9020A Screen Replacement: passo 19, imagem 2 %32
      • Use the plastic opening tool to pry the screen out of the device.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 30
Ao todo: 969
