Ir para o conteúdo principal
ATT EL52300 Speaker Replacement
O que você precisa
  1. ATT EL52300 Speaker Replacement, Battery: passo 1, imagem 1 %32 ATT EL52300 Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 Speaker Replacement: passo 2, imagem 1 %32
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
  3. ATT EL52300 Speaker Replacement, Motherboard: passo 3, imagem 1 %32 ATT EL52300 Speaker Replacement, Motherboard: passo 3, imagem 2 %32
    • Remove the two 3.75 mm screws with a PH1 screwdriver.
  4. ATT EL52300 Speaker Replacement: passo 4, imagem 1 %32 ATT EL52300 Speaker Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to remove the handset case.
    • Be careful to not lift the case too far as the ringer cable is attached to the case.
  5. ATT EL52300 Speaker Replacement: passo 5, imagem 1 %32 ATT EL52300 Speaker Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
    • Use an anti-static wrist strap to prevent damage to the motherboard.
  6. ATT EL52300 Speaker Replacement, Speaker: passo 6, imagem 1 %32
    • Using the soldering tool, disconnect the speaker from your handset's motherboard.
    • Please refer to the Como soldar e dessoldar contatos for instructions on how to solder.
Conclusão
Eddie Barnes
Membro desde: 02/10/16
323 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-1, Sullivan Spring 2016 Membro de USF Tampa, Team 1-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G1
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 396
