Introdução
Use this keypad replacement guide if buttons are missing or damaged. A potential hazard would be affecting the motherboard through the charge that you internally carry, therefore you should use the anti-static wrist strap to prevent this. References to the other guides will be used.
O que você precisa
Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
