Ir para o conteúdo principal
ATT CL2940 Speakerphone Replacement
O que você precisa
  1. ATT CL2940 Speakerphone Replacement, Back Panel: passo 1, imagem 1 %32 ATT CL2940 Speakerphone Replacement, Back Panel: passo 1, imagem 2 %32 ATT CL2940 Speakerphone Replacement, Back Panel: passo 1, imagem 3 %32
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. ATT CL2940 Speakerphone Replacement: passo 2, imagem 1 %32 ATT CL2940 Speakerphone Replacement: passo 2, imagem 2 %32 ATT CL2940 Speakerphone Replacement: passo 2, imagem 3 %32
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
  3. ATT CL2940 Speakerphone Replacement: passo 3, imagem 1 %32
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
  4. ATT CL2940 Speakerphone Replacement, Speakerphone: passo 4, imagem 1 %32 ATT CL2940 Speakerphone Replacement, Speakerphone: passo 4, imagem 2 %32
    • Remove the front panel of the device as shown.
  5. ATT CL2940 Speakerphone Replacement: passo 5, imagem 1 %32 ATT CL2940 Speakerphone Replacement: passo 5, imagem 2 %32 ATT CL2940 Speakerphone Replacement: passo 5, imagem 3 %32
    • Desolder the speakerphone with a soldering iron.
    • If you are unfamiliar with solder, check out the article on soldering and be very careful. The iron is hot!
  6. ATT CL2940 Speakerphone Replacement: passo 6, imagem 1 %32 ATT CL2940 Speakerphone Replacement: passo 6, imagem 2 %32
    • Use the soldering iron to reconnect the wires to the new speaker.
    • Place the new speaker back in place.
    • Make sure that all of the components are back in place.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Charles Messmore
Membro desde: 02/15/16
541 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team 1-1, Harley Spring 2016 Membro de IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
Membros da 4
Autoria de 13 guias
Um comentário
Why do all these repairs require NO PARTS to replace defective parts?
And, of course< there is no links to a place to purchase the needed parts...
rpoland - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 609
