Ir para o conteúdo principal
ATT CL2940 Phone Jack Replacement
O que você precisa
  1. ATT CL2940 Phone Jack Replacement, Back Panel: passo 1, imagem 1 %32 ATT CL2940 Phone Jack Replacement, Back Panel: passo 1, imagem 2 %32 ATT CL2940 Phone Jack Replacement, Back Panel: passo 1, imagem 3 %32
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
    Pergunte ao FixBot
    Comentar
  2. ATT CL2940 Phone Jack Replacement: passo 2, imagem 1 %32 ATT CL2940 Phone Jack Replacement: passo 2, imagem 2 %32 ATT CL2940 Phone Jack Replacement: passo 2, imagem 3 %32
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
    Pergunte ao FixBot
    Comentar
  3. ATT CL2940 Phone Jack Replacement: passo 3, imagem 1 %32
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
    Pergunte ao FixBot
    Comentar
  4. ATT CL2940 Phone Jack Replacement, Phone Jack: passo 4, imagem 1 %32 ATT CL2940 Phone Jack Replacement, Phone Jack: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using the precision tweezers, bend the golden tips of the green and red wires upward.
    • The wires are pulled out from two of the six holes. Make sure you remember which holes you pulled the wires out from.
    • Bend the wires slowly and gently to avoid breaking them.
    Pergunte ao FixBot
    Comentar
  5. ATT CL2940 Phone Jack Replacement: passo 5, imagem 1 %32 ATT CL2940 Phone Jack Replacement: passo 5, imagem 2 %32 ATT CL2940 Phone Jack Replacement: passo 5, imagem 3 %32
    • After bending the golden wire tips, pull the wires out from the back side of the phone jack.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Noor Assaf
Membro desde: 02/15/16
312 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 1-1, Harley Spring 2016 Membro de IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Membros
Autoria de 13 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 44
Ao todo: 1,039
