Ir para o conteúdo principal
ATT CL2940 Buttons and/or Keypad Replacement
O que você precisa
  1. ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: passo 1, imagem 1 %32 ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: passo 1, imagem 2 %32 ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: passo 1, imagem 3 %32
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
    Pergunte ao FixBot
    Comentar
  2. ATT CL2940 Buttons and/or Keypad Replacement: passo 2, imagem 1 %32 ATT CL2940 Buttons and/or Keypad Replacement: passo 2, imagem 2 %32 ATT CL2940 Buttons and/or Keypad Replacement: passo 2, imagem 3 %32
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
    Pergunte ao FixBot
    Comentar
  3. ATT CL2940 Buttons and/or Keypad Replacement: passo 3, imagem 1 %32
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
    Pergunte ao FixBot
    Comentar
  4. ATT CL2940 Buttons and/or Keypad Replacement, Buttons and/or Keypad: passo 4, imagem 1 %32 ATT CL2940 Buttons and/or Keypad Replacement, Buttons and/or Keypad: passo 4, imagem 2 %32
    • Unscrew five 5.6 mm screws on top level, yellow motherboard.
    Pergunte ao FixBot
    Comentar
  5. ATT CL2940 Buttons and/or Keypad Replacement: passo 5, imagem 1 %32 ATT CL2940 Buttons and/or Keypad Replacement: passo 5, imagem 2 %32 ATT CL2940 Buttons and/or Keypad Replacement: passo 5, imagem 3 %32
    • Lift the top level Motherboard in order to get to the lower level Motherboard.
    Pergunte ao FixBot
    Comentar
  6. ATT CL2940 Buttons and/or Keypad Replacement: passo 6, imagem 1 %32 ATT CL2940 Buttons and/or Keypad Replacement: passo 6, imagem 2 %32
    • Unscrew the 5.6 mm screw on the clip behind the Screen as shown.
    Pergunte ao FixBot
    Comentar
  7. ATT CL2940 Buttons and/or Keypad Replacement: passo 7, imagem 1 %32 ATT CL2940 Buttons and/or Keypad Replacement: passo 7, imagem 2 %32
    • Unscrew five 5.6 mm screws on the lower level Motherboard.
    • Keep the screws for the upper and lower level motherboard separated.
    Pergunte ao FixBot
    Comentar
  8. ATT CL2940 Buttons and/or Keypad Replacement: passo 8, imagem 1 %32 ATT CL2940 Buttons and/or Keypad Replacement: passo 8, imagem 2 %32
    • Lift the lower level Motherboard upward.
    • Remove the silicon pad above the buttons.
    Pergunte ao FixBot
    Comentar
  9. ATT CL2940 Buttons and/or Keypad Replacement: passo 9, imagem 1 %32 ATT CL2940 Buttons and/or Keypad Replacement: passo 9, imagem 2 %32
    • Push the Button Panel upward and pull it out.
    • Replace the entire Button Panel or a single defective button.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
IUPUI, Team 1-1, Harley Spring 2016 Membro de IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Membros
Autoria de 13 guias
1Comentário do guia
Great explanation! Where would you recommend buying replacement buttons for the phone? Thanks
Sean Richardson - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 38
Ao todo: 925
