Ir para o conteúdo principal
AT-LP60X Setup Guide
  1. AT-LP60X Setup Guide, Place Turntable: passo 1, imagem 1 %32 AT-LP60X Setup Guide, Place Turntable: passo 1, imagem 2 %32
    • Place your turntable on a clear, flat surface.
    • Ensure there is no power connected to the turntable at this time.
    Pergunte ao FixBot
    Comentar
  2. AT-LP60X Setup Guide, Locate and Install Platter/Belt: passo 2, imagem 1 %32
    • Obtain the silver metal platter.
    • Verify that the belt is installed around the inner ring of the platter.
    Pergunte ao FixBot
    Comentar
  3. AT-LP60X Setup Guide, Install Platter: passo 3, imagem 1 %32 AT-LP60X Setup Guide, Install Platter: passo 3, imagem 2 %32
    • Place the platter on the center spindle.
    • Rotate the platter to show the gold pulley of the motor.
    • Stretch the belt from the platter over the gold pulley of the motor.
    Pergunte ao FixBot
    Comentar
  4. AT-LP60X Setup Guide, Preform Mechanical Reset: passo 4, imagem 1 %32 AT-LP60X Setup Guide, Preform Mechanical Reset: passo 4, imagem 2 %32
    • Place the slipmat on top of the platter and press the STOP button.
    • With your right hand, hold the tone arm in place.
    • [OPTIONAL] use the included hook and twist tie for this step.
    • With your left hand, rotate the platter clockwise about 10 times.
    • You should hear a series of clicks and pops.
    Pergunte ao FixBot
    Comentar
  5. AT-LP60X Setup Guide, Reconnect Turntable: passo 5, imagem 1 %32
    • Reconnect the power supply.
    • Connect the 3.5mm to RCA to your speakers.
    • For powered speakers the output switch should be in "LINE", if connecting to an amp/phono input the output should be in "PHONO"
    • The output switch position does not matter if you are connecting to a Bluetooth speaker.
    Pergunte ao FixBot
    Comentar
  6. AT-LP60X Setup Guide, Prepare Tonearm: passo 6, imagem 1 %32 AT-LP60X Setup Guide, Prepare Tonearm: passo 6, imagem 2 %32 AT-LP60X Setup Guide, Prepare Tonearm: passo 6, imagem 3 %32
    • Remove the clear plastic cover from the stylus (if present) by sliding the COVER ONLY directly towards the front of the turntable.
    • Unsecure the twist tie from the built-in hook (if present).
    • Ensure the tone arm lift button is in the outward position.
    • The setup is now complete and you are ready to try a record!
    Pergunte ao FixBot
    Comentar
Conclusão
If you have any trouble setting up your turntable and/or a new problem arises, feel free to contact a technician at (330)686-2600 ext.5004 or service@atus.com
Uma outra pessoa concluiu este guia.
Anthony @ ATUS
Membro desde: 02/28/19
1.195 Reputação
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 23
Últimos 30 dias: 88
Ao todo: 1,088
