Introdução
This guide will show you how to locate, remove, and replace the buttons on the AT&T NVG510 modem. In the event that a button becomes stuck or your router becomes unresponsive when you press a button, you may need to replace it. This guide does require you to be able to operate a soldering iron carefully.
O que você precisa
Place the router on one side so that the rubber stands are facing upward.
Remove the stands from the left corners only, relative to the AT&T logo if facing upright.
Remove two screws using a 2.0 flathead screwdriver.
3 outras pessoas executaram este guia.
