Introdução
If your front facing camera does not work, you can use this guide to take your device apart and replace it. Make sure the battery is completely removed before working on the camera as to prevent shorts in the circuitry As a precautions ground yourself to prevent frying the internal components. Also make sure to keep track of screws and label them.
O que você precisa
Use the plastic tool to pry between the silver bezel and the back case
Work the tool around the device to free the back case
Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
