Ir para o conteúdo principal
ASUS ZenPad S 8.0 Battery Replacement
O que você precisa
    1. ASUS ZenPad S 8.0 Battery Replacement, Rear Cover Removal: passo 1, imagem 1 %32 ASUS ZenPad S 8.0 Battery Replacement, Rear Cover Removal: passo 1, imagem 2 %32 ASUS ZenPad S 8.0 Battery Replacement, Rear Cover Removal: passo 1, imagem 3 %32
      • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
      • Use the plastic tool to pry between the silver bezel and the back case
      • Work the tool around the device to free the back case
      Pergunte ao FixBot
      Comentar
    2. ASUS ZenPad S 8.0 Battery Replacement: passo 2, imagem 1 %32 ASUS ZenPad S 8.0 Battery Replacement: passo 2, imagem 2 %32
      • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
      • Do not kink the ribbon cables as they can break easily
      Pergunte ao FixBot
      Comentar
    3. ASUS ZenPad S 8.0 Battery Replacement: passo 3, imagem 1 %32 ASUS ZenPad S 8.0 Battery Replacement: passo 3, imagem 2 %32 ASUS ZenPad S 8.0 Battery Replacement: passo 3, imagem 3 %32
      • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
      Pergunte ao FixBot
      Comentar
    4. ASUS ZenPad S 8.0 Battery Replacement: passo 4, imagem 1 %32 ASUS ZenPad S 8.0 Battery Replacement: passo 4, imagem 2 %32
      • Remove all 9 of the 1.5mm #00 Philips screws
      • Gently lift the battery out of the device
      • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Ensure that the MicroSD card slot cover is in its closed position before re-attaching the rear cover.
29 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 2-2, Cagle Fall 2016 Membro de USF Tampa, Team 2-2, Cagle Fall 2016
USFT-CAGLE-F16S2G2
4 Membros
Autoria de 5 guias
20Comentários do guia
Thanks for this tutorial. Any chance anybody knows the part number for the battery and a good source?
danpobrien - Responder Compartilhar
Yes, A good tutorial but part number for the battery would be useful
celdor - Responder Compartilhar
Doh! its in the pictures its a C11Pn9H should have spotted that.
The original battery says” Rating 3.8v 15.2 Wh” and “Capacity 4000mAh(TYP) 3984mAh(MIN)”
Clone batteries may be lower. Wish I’d bought a “factory battery”
license - Responder Compartilhar
Tutorial was perfect, much easier than I thought. Unfortunately swapping the battery did not fix my tablet, but I feel a lot more confident now to try fixing things like this first instead of just automatically throwing them away. Thanks!
cdclemons - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 70
Ao todo: 26,213
