Ir para o conteúdo principal
ASUS X550LB-DS71 Motherboard Replacement
O que você precisa
  1. ASUS X550LB-DS71 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 ASUS X550LB-DS71 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 ASUS X550LB-DS71 Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
    Pergunte ao FixBot
    Comentar
  2. ASUS X550LB-DS71 Motherboard Replacement: passo 2, imagem 1 %32
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
    • At this point, it is advised to disconnect the hard drive from the motherboard.
    Pergunte ao FixBot
    Comentar
  3. ASUS X550LB-DS71 Motherboard Replacement: passo 3, imagem 1 %32 ASUS X550LB-DS71 Motherboard Replacement: passo 3, imagem 2 %32 ASUS X550LB-DS71 Motherboard Replacement: passo 3, imagem 3 %32
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
    Pergunte ao FixBot
    Comentar
  4. ASUS X550LB-DS71 Motherboard Replacement: passo 4, imagem 1 %32 ASUS X550LB-DS71 Motherboard Replacement: passo 4, imagem 2 %32
    • Locate the three ribbon connectors.
    • Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
    • Once the tabs are released, the ribbons will be easy to remove. Do not pull on the ribbons.
    Pergunte ao FixBot
    Comentar
  5. ASUS X550LB-DS71 Motherboard Replacement: passo 5, imagem 1 %32 ASUS X550LB-DS71 Motherboard Replacement: passo 5, imagem 2 %32
    • Locate the gold ribbon connecting the motherboard to the display.
    • Lift up the tape and disconnect the ribbon.
    Pergunte ao FixBot
    Comentar
  6. ASUS X550LB-DS71 Motherboard Replacement: passo 6, imagem 1 %32 ASUS X550LB-DS71 Motherboard Replacement: passo 6, imagem 2 %32
    • Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
    Pergunte ao FixBot
    Comentar
  7. ASUS X550LB-DS71 Motherboard Replacement: passo 7, imagem 1 %32 ASUS X550LB-DS71 Motherboard Replacement: passo 7, imagem 2 %32
    • Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
    • Disconnect the optical drive from the motherboard by sliding it to the right.
    Pergunte ao FixBot
    Comentar
  8. ASUS X550LB-DS71 Motherboard Replacement: passo 8, imagem 1 %32 ASUS X550LB-DS71 Motherboard Replacement: passo 8, imagem 2 %32 ASUS X550LB-DS71 Motherboard Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Flip the motherboard to show the underside.
    • Locate the two square connections attached to the motherboard.
    • Disconnect them using blunt tweezers.
    Pergunte ao FixBot
    Comentar
  9. ASUS X550LB-DS71 Motherboard Replacement: passo 9, imagem 1 %32 ASUS X550LB-DS71 Motherboard Replacement: passo 9, imagem 2 %32 ASUS X550LB-DS71 Motherboard Replacement: passo 9, imagem 3 %32
    • Using the Phillips #0 Screwdriver, remove the seven 2mm screws at the marked locations.
    • Remove the heat sink from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Nathan Dyer
Membro desde: 09/25/17
550 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S16-G1, Eyestone Fall 2017 Membro de USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 46
Ao todo: 2,671
