Ir para o conteúdo principal
ASUS X550LB-DS71 Fan Replacement
O que você precisa
  1. ASUS X550LB-DS71 Fan Replacement, Fan: passo 1, imagem 1 %32 ASUS X550LB-DS71 Fan Replacement, Fan: passo 1, imagem 2 %32 ASUS X550LB-DS71 Fan Replacement, Fan: passo 1, imagem 3 %32
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
    Pergunte ao FixBot
    Comentar
  2. ASUS X550LB-DS71 Fan Replacement: passo 2, imagem 1 %32
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
    • At this point, it is advised to disconnect the hard drive from the motherboard.
    Pergunte ao FixBot
    Comentar
  3. ASUS X550LB-DS71 Fan Replacement: passo 3, imagem 1 %32 ASUS X550LB-DS71 Fan Replacement: passo 3, imagem 2 %32 ASUS X550LB-DS71 Fan Replacement: passo 3, imagem 3 %32
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
    Pergunte ao FixBot
    Comentar
  4. ASUS X550LB-DS71 Fan Replacement: passo 4, imagem 1 %32 ASUS X550LB-DS71 Fan Replacement: passo 4, imagem 2 %32
    • Locate the three ribbon connectors.
    • Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
    • Once the tabs are released, the ribbons will be easy to remove. Do not pull on the ribbons.
    Pergunte ao FixBot
    Comentar
  5. ASUS X550LB-DS71 Fan Replacement: passo 5, imagem 1 %32 ASUS X550LB-DS71 Fan Replacement: passo 5, imagem 2 %32
    • Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
    Pergunte ao FixBot
    Comentar
  6. ASUS X550LB-DS71 Fan Replacement: passo 6, imagem 1 %32 ASUS X550LB-DS71 Fan Replacement: passo 6, imagem 2 %32
    • Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
    • Disconnect the optical drive from the motherboard by sliding it to the right.
    Pergunte ao FixBot
    Comentar
  7. ASUS X550LB-DS71 Fan Replacement: passo 7, imagem 1 %32 ASUS X550LB-DS71 Fan Replacement: passo 7, imagem 2 %32 ASUS X550LB-DS71 Fan Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Flip the motherboard to show the underside.
    • Locate the square fan connection attached to the motherboard.
    • Disconnect it using the tweezers (blunt).
    Pergunte ao FixBot
    Comentar
  8. ASUS X550LB-DS71 Fan Replacement: passo 8, imagem 1 %32
    • Remove the black tape from the fan as seen in the marked location.
    • At this point, the fan is now disconnected from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Nathan Dyer
Membro desde: 09/25/17
550 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S16-G1, Eyestone Fall 2017 Membro de USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Membros
Autoria de 5 guias
1Comentário do guia
my mouse of laptop not working pls guide to repaire
Parneet Bhatti (Mantri) - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 30
Ao todo: 1,505
