Ir para o conteúdo principal
ASUS X550LB-DS71 Display Panel Replacement
O que você precisa
  1. ASUS X550LB-DS71 Display Panel Replacement, Display Panel: passo 1, imagem 1 %32 ASUS X550LB-DS71 Display Panel Replacement, Display Panel: passo 1, imagem 2 %32 ASUS X550LB-DS71 Display Panel Replacement, Display Panel: passo 1, imagem 3 %32
    • Flip open the laptop with the screen facing towards you.
    • Using the plastic opening tool, remove the square tape from the marked locations.
    • Use the Phillips #0 Screwdriver to remove the two 2mm screws from those locations.
    Pergunte ao FixBot
    Comentar
  2. ASUS X550LB-DS71 Display Panel Replacement: passo 2, imagem 1 %32 ASUS X550LB-DS71 Display Panel Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, open the front cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
    Pergunte ao FixBot
    Comentar
  3. ASUS X550LB-DS71 Display Panel Replacement: passo 3, imagem 1 %32 ASUS X550LB-DS71 Display Panel Replacement: passo 3, imagem 2 %32 ASUS X550LB-DS71 Display Panel Replacement: passo 3, imagem 3 %32
    • Peel off the tape located on the left and right side of the display monitor.
    • Use the Phillips #0 screwdriver to remove the screws at the marked locations in each corner of the display.
    Pergunte ao FixBot
    Comentar
  4. ASUS X550LB-DS71 Display Panel Replacement: passo 4, imagem 1 %32 ASUS X550LB-DS71 Display Panel Replacement: passo 4, imagem 2 %32 ASUS X550LB-DS71 Display Panel Replacement: passo 4, imagem 3 %32
    • Place the display monitor face down to expose the ribbon connector.
    • Remove the ribbon connector to separate the display monitor from the rest of the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Nathan Dyer
Membro desde: 09/25/17
550 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S16-G1, Eyestone Fall 2017 Membro de USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 20
Ao todo: 1,405
