Ir para o conteúdo principal
ASUS X502CA Fan Replacement
O que você precisa
    1. ASUS X502CA Fan Replacement, Fan: passo 1, imagem 1 %32
      • Use a Phillips #00 screwdriver to remove:
      • Eight 9 mm screws.
      • Four 5 mm screws.
      Pergunte ao FixBot
      Comentar
    2. ASUS X502CA Fan Replacement: passo 2, imagem 1 %32
      • Remove the keyboard cover panel by using a plastic opening tool to carefully pop off the clips around the perimeter.
      • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
      Pergunte ao FixBot
      Comentar
    3. ASUS X502CA Fan Replacement: passo 3, imagem 1 %32
      Ferramenta utilizada neste passo:
      • The keyboard cover panel is connected to the motherboard with ribbons; be careful not to damage them.
      • Lift the keyboard cover carefully.
      • Disconnect the keyboard and touch-pad ribbons using tweezers.
      Pergunte ao FixBot
      Comentar
    4. ASUS X502CA Fan Replacement: passo 4, imagem 1 %32
      • Remove the keyboard cover panel.
      Pergunte ao FixBot
      Comentar
    5. ASUS X502CA Fan Replacement: passo 5, imagem 1 %32
      • Fold up the black plastic arms securing the cables and disconnect them using tweezers or finger nails.
      • If these are not unplugged, the motherboard may shock you.
      Pergunte ao FixBot
      Comentar
    6. ASUS X502CA Fan Replacement: passo 6, imagem 1 %32
      • Disconnect the remaining connectors using tweezers or your finger nails.
      Pergunte ao FixBot
      Comentar
    7. ASUS X502CA Fan Replacement: passo 7, imagem 1 %32
      • Remove the six 5 mm screws using the Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    8. ASUS X502CA Fan Replacement: passo 8, imagem 1 %32
      • Flip the motherboard over and away from the screen.
      Pergunte ao FixBot
      Comentar
    9. ASUS X502CA Fan Replacement: passo 9, imagem 1 %32
      • Remove the two 5 mm screws with a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    10. ASUS X502CA Fan Replacement: passo 10, imagem 1 %32
      • Unplug the fan's power connector using tweezers or your fingernails.
      Pergunte ao FixBot
      Comentar
    11. ASUS X502CA Fan Replacement: passo 11, imagem 1 %32
      • Peel off the marked strip using your fingers.
      Pergunte ao FixBot
      Comentar
    12. ASUS X502CA Fan Replacement: passo 12, imagem 1 %32
      • Lift the fan up and away from the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
David Conner
Membro desde: 03/03/15
292 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 14-1, Shirley Winter 2015 Membro de Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Membros
Autoria de 35 guias
2Comentários do guia
Great tutorial.
Arthur Rumrill - Responder Compartilhar
Thanks Bro! :)
Crispino A Meola - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 45
Ao todo: 8,282
