Ir para o conteúdo principal
ASUS X44H-BBR4 Fan Replacement
O que você precisa
  1. ASUS X44H-BBR4 Fan Replacement, Battery: passo 1, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement, Battery: passo 1, imagem 2 %32
    • Flip the device over.
    Pergunte ao FixBot
    Comentar
  2. ASUS X44H-BBR4 Fan Replacement: passo 2, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 2, imagem 2 %32 ASUS X44H-BBR4 Fan Replacement: passo 2, imagem 3 %32
    • Slide the right lock button to the unlock position.
    • After it is unlocked, a red line will be visible.
    Pergunte ao FixBot
    Comentar
  3. ASUS X44H-BBR4 Fan Replacement: passo 3, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 3, imagem 2 %32
    • Slide the left lock button into the unlock position and hold.
    Pergunte ao FixBot
    Comentar
  4. ASUS X44H-BBR4 Fan Replacement: passo 4, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 4, imagem 2 %32 ASUS X44H-BBR4 Fan Replacement: passo 4, imagem 3 %32
    • While holding the left lock button in the unlock position, push the battery from the center away from you.
    Pergunte ao FixBot
    Comentar
  5. ASUS X44H-BBR4 Fan Replacement, Keyboard: passo 5, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement, Keyboard: passo 5, imagem 2 %32
    • Open the laptop to show the keyboard.
    Pergunte ao FixBot
    Comentar
  6. ASUS X44H-BBR4 Fan Replacement: passo 6, imagem 1 %32
    • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
    • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
    Pergunte ao FixBot
    Comentar
  7. ASUS X44H-BBR4 Fan Replacement: passo 7, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 7, imagem 2 %32 ASUS X44H-BBR4 Fan Replacement: passo 7, imagem 3 %32
    • Don't pull too hard on the keys otherwise they may fall off.
    • Push the latch away from the keyboard using the spudger point.
    • While pushing the latches use a plastic opening tool and pull up on a key near it.
    • Continue along the rest of the keyboard until it is released at all four latches.
    Pergunte ao FixBot
    Comentar
  8. ASUS X44H-BBR4 Fan Replacement: passo 8, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 8, imagem 2 %32
    • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
    • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
    Pergunte ao FixBot
    Comentar
  9. ASUS X44H-BBR4 Fan Replacement: passo 9, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 9, imagem 2 %32
    • Flip the keyboard over to reveal the back of it and what is underneath.
    Pergunte ao FixBot
    Comentar
  10. ASUS X44H-BBR4 Fan Replacement: passo 10, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 10, imagem 2 %32 ASUS X44H-BBR4 Fan Replacement: passo 10, imagem 3 %32
    • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
    • Gently pull out the ribbon cable from the connector piece.
    Pergunte ao FixBot
    Comentar
  11. ASUS X44H-BBR4 Fan Replacement: passo 11, imagem 1 %32
    • Remove the keyboard completely.
    Pergunte ao FixBot
    Comentar
  12. ASUS X44H-BBR4 Fan Replacement, Hard Drive: passo 12, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement, Hard Drive: passo 12, imagem 2 %32
    • Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
    Pergunte ao FixBot
    Comentar
  13. ASUS X44H-BBR4 Fan Replacement: passo 13, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 13, imagem 2 %32
    • Once the screws are removed, slide the back panel away from the computer.
    Pergunte ao FixBot
    Comentar
  14. ASUS X44H-BBR4 Fan Replacement: passo 14, imagem 1 %32
    • Remove the 9mm Phillips head screw in the left bottom corner of the hard drive with the PH0 bit.
    Pergunte ao FixBot
    Comentar
  15. ASUS X44H-BBR4 Fan Replacement: passo 15, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 15, imagem 2 %32
    • Slide the hard drive to the left, unlocking it from its default position.
    Pergunte ao FixBot
    Comentar
  16. ASUS X44H-BBR4 Fan Replacement: passo 16, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 16, imagem 2 %32
    • Pull the hard drive upwards and take it out of its position.
    Pergunte ao FixBot
    Comentar
  17. ASUS X44H-BBR4 Fan Replacement: passo 17, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 17, imagem 2 %32 ASUS X44H-BBR4 Fan Replacement: passo 17, imagem 3 %32
    • Remove two 3mm Phillips head screws, one located on each side of the metal casing holding the hard drive using the PH0 bit.
    Pergunte ao FixBot
    Comentar
  18. ASUS X44H-BBR4 Fan Replacement: passo 18, imagem 1 %32
    • Pull upwards on the metal casing and it will come off.
    Pergunte ao FixBot
    Comentar
  19. ASUS X44H-BBR4 Fan Replacement, Front Panel: passo 19, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement, Front Panel: passo 19, imagem 2 %32 ASUS X44H-BBR4 Fan Replacement, Front Panel: passo 19, imagem 3 %32
    • Lift up the black lock holding the ribbon.
    • Using the blue tab, pull out the ribbon.
    • Pull gently on the ribbon to remove the risk of damaging the ribbon.
    Pergunte ao FixBot
    Comentar
  20. ASUS X44H-BBR4 Fan Replacement: passo 20, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  21. ASUS X44H-BBR4 Fan Replacement: passo 21, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 21, imagem 2 %32
    • Remove the five 9 mm Phillips head screws with the PH0 bit.
    Pergunte ao FixBot
    Comentar
  22. ASUS X44H-BBR4 Fan Replacement: passo 22, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 22, imagem 2 %32
    • Flip the laptop on its side so that the red line indicated in the pictures is facing upwards.
    Pergunte ao FixBot
    Comentar
  23. ASUS X44H-BBR4 Fan Replacement: passo 23, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 23, imagem 2 %32
    • Pull up on the disk drive and remove.
    Pergunte ao FixBot
    Comentar
  24. ASUS X44H-BBR4 Fan Replacement: passo 24, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 24, imagem 2 %32
    • Close the laptop and flip it over.
    • Remove the six 12.5 mm screws Phillips head and the five 9 mm screws remaining with the PH0 bit.
    Pergunte ao FixBot
    Comentar
  25. ASUS X44H-BBR4 Fan Replacement: passo 25, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 25, imagem 2 %32 ASUS X44H-BBR4 Fan Replacement: passo 25, imagem 3 %32
    • Flip the device back over and open the laptop.
    • Using the nylon or metal spudger, gently pry off the panel by moving the spudger along the seam.
    • You should hear clicking sounds as the front panel is being removed from the base.
    Pergunte ao FixBot
    Comentar
  26. ASUS X44H-BBR4 Fan Replacement: passo 26, imagem 1 %32
    • Remove the panel.
    • The laptop will now become heavier to the front so it will tend to fall on the back side of the screen.
    Pergunte ao FixBot
    Comentar
  27. ASUS X44H-BBR4 Fan Replacement, MotherBoard: passo 27, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement, MotherBoard: passo 27, imagem 2 %32
    • Remove the 5mm Phillips head screw using the PH0 bit.
    Pergunte ao FixBot
    Comentar
  28. ASUS X44H-BBR4 Fan Replacement: passo 28, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 28, imagem 2 %32 ASUS X44H-BBR4 Fan Replacement: passo 28, imagem 3 %32
    • Pull up on the tape holding the tan cable in place.
    • While holding the tape push up on each side of the cable connector to disconnect it.
    Pergunte ao FixBot
    Comentar
  29. ASUS X44H-BBR4 Fan Replacement: passo 29, imagem 1 %32
    • Gently pull out the cable connector.
    Pergunte ao FixBot
    Comentar
  30. ASUS X44H-BBR4 Fan Replacement: passo 30, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 30, imagem 2 %32 ASUS X44H-BBR4 Fan Replacement: passo 30, imagem 3 %32
    • Gently pull out the USB connector attached to the motherboard.
    Pergunte ao FixBot
    Comentar
  31. ASUS X44H-BBR4 Fan Replacement: passo 31, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 31, imagem 2 %32
    • Remove the red and white wire connector next to the fan.
    Pergunte ao FixBot
    Comentar
  32. ASUS X44H-BBR4 Fan Replacement: passo 32, imagem 1 %32
    • Take out the motherboard
    • There are still two wires connected to the bottom of the motherboard so remove carefully.
    Pergunte ao FixBot
    Comentar
  33. ASUS X44H-BBR4 Fan Replacement: passo 33, imagem 1 %32
    • Flip the motherboard over next to the laptop base.
    Pergunte ao FixBot
    Comentar
  34. ASUS X44H-BBR4 Fan Replacement: passo 34, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 34, imagem 2 %32 ASUS X44H-BBR4 Fan Replacement: passo 34, imagem 3 %32
    • Remove the white and black wire.
    • The motherboard is not completely separated from the base of the computer.
    Pergunte ao FixBot
    Comentar
  35. ASUS X44H-BBR4 Fan Replacement, Fan: passo 35, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement, Fan: passo 35, imagem 2 %32 ASUS X44H-BBR4 Fan Replacement, Fan: passo 35, imagem 3 %32
    • Remove the black piece of tape located on each side of the fan and vent, connecting the two components.
    Pergunte ao FixBot
    Comentar
  36. ASUS X44H-BBR4 Fan Replacement: passo 36, imagem 1 %32 ASUS X44H-BBR4 Fan Replacement: passo 36, imagem 2 %32 ASUS X44H-BBR4 Fan Replacement: passo 36, imagem 3 %32
    • Pull up on the four wires (red, yellow, blue and black) connecting the fan to the motherboard.
    • Remove fan by pulling it upwards.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 4-3, Catania Fall 2015 Membro de UMass Dartmouth, Team 4-3, Catania Fall 2015
UMASSD-CATANIA-F15S4G3
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Ao todo: 938
