Ir para o conteúdo principal
ASUS VG248 Disassembly
O que você precisa
  1. ASUS VG248 Disassembly, ASUS VG248 Disassembly: passo 1, imagem 1 %32 ASUS VG248 Disassembly, ASUS VG248 Disassembly: passo 1, imagem 2 %32
    • Before you begin, lay the monitor face down on a smooth, clean surface.
    • Four rubbery covers hide four screws in the rear of the monitor.
    • Pry out the plastic covers with a stiff pointed tool, like a metal spudger.
    Pergunte ao FixBot
    Comentar
  2. ASUS VG248 Disassembly: passo 2, imagem 1 %32
    • Remove the four 13.4 mm Philips #1 screws securing the monitor stand.
    Pergunte ao FixBot
    Comentar
  3. ASUS VG248 Disassembly: passo 3, imagem 1 %32 ASUS VG248 Disassembly: passo 3, imagem 2 %32
    • Remove the stand from the display.
    Pergunte ao FixBot
    Comentar
  4. ASUS VG248 Disassembly: passo 4, imagem 1 %32 ASUS VG248 Disassembly: passo 4, imagem 2 %32
    • The display bezel is held to the rear case by plastic clips that can be released by pulling straight up on the bezel.
    • Rather than use any prying tools that could damage the LCD, it's best to just pull with your fingers. A thin cloth will both protect your fingertips and prevent you from smudging the LCD.
    • Lay the cloth over one of the long edges of the display.
    • Grip the side of the bezel through the cloth and lift straight up. A few clips in the center will pop free.
    • Be careful to pull straight up, and not pry against the display. Pushing down on the display could damage it.
    Pergunte ao FixBot
    Comentar
  5. ASUS VG248 Disassembly: passo 5, imagem 1 %32 ASUS VG248 Disassembly: passo 5, imagem 2 %32
    • Repeat the procedure around the display, lifting up the center of the next side.
    Pergunte ao FixBot
    Comentar
  6. ASUS VG248 Disassembly: passo 6, imagem 1 %32 ASUS VG248 Disassembly: passo 6, imagem 2 %32
    • Move around to the other long side and lift up on the center of the bezel.
    Pergunte ao FixBot
    Comentar
  7. ASUS VG248 Disassembly: passo 7, imagem 1 %32 ASUS VG248 Disassembly: passo 7, imagem 2 %32
    • Grip the center of the final side and lift the bezel away from the rear case.
    Pergunte ao FixBot
    Comentar
  8. ASUS VG248 Disassembly: passo 8, imagem 1 %32 ASUS VG248 Disassembly: passo 8, imagem 2 %32
    • Now that you've freed the centers of the four sides, it's time to move on to the corners.
    • Each corner is secured by two large clips that can't be freed by just pulling straight up like you did with the sides.
    • In the next step, you'll be pushing in on the corner clip on the left of the bottom edge of the bezel.
    Pergunte ao FixBot
    Comentar
  9. ASUS VG248 Disassembly: passo 9, imagem 1 %32 ASUS VG248 Disassembly: passo 9, imagem 2 %32
    Ferramenta utilizada neste passo:
    Jimmy
    $7.95
    • Using a thin stiff prying device, like a Jimmy, press in against the bottom clip in the lower left corner (beneath the HDMI logo).
    • While pressing the clip in, pull up on the lower edge of the bezel. The entire corner should pop free.
    Pergunte ao FixBot
    Comentar
  10. ASUS VG248 Disassembly: passo 10, imagem 1 %32 ASUS VG248 Disassembly: passo 10, imagem 2 %32 ASUS VG248 Disassembly: passo 10, imagem 3 %32
    • Once you've freed one corner, you should be able to gently twist the bezel off, freeing all of the remaining corners.
    • If any corners are particularly stubborn, repeat the previous step on the difficult corner.
    Pergunte ao FixBot
    Comentar
  11. ASUS VG248 Disassembly: passo 11, imagem 1 %32
    • Remove the bezel.
    Pergunte ao FixBot
    Comentar
  12. ASUS VG248 Disassembly: passo 12, imagem 1 %32 ASUS VG248 Disassembly: passo 12, imagem 2 %32
    • Lift the LCD out of the rear case.
    • The row of adjustment buttons will come out of the case with the display, attached by a thin ribbon cable. Take care not to damage the cable.
    Pergunte ao FixBot
    Comentar
  13. ASUS VG248 Disassembly: passo 13, imagem 1 %32
    • With the casing removed, you now have access to the button board, cables, and the housing over the motherboard components.
    Pergunte ao FixBot
    Comentar
Conclusão
23 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
477.626 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 26.617 guias
11Comentários do guia
Do you know of any place that sell the replacement lcd screen?
treymcbrd - Responder Compartilhar
Hi there, I have a little thunderbug trapped in the LCD is it possible to take the metal casing at the front of to reomve said bug? Thanks
TJ Grainger - Responder Compartilhar
You could yes, but be very careful NOT to introduce dust into the panel!
Bertus van den Dikkenberg - Responder Compartilhar
Hi. A really small bug got stuck within my screen and I accidentally squished it so now it’s dead in there and I want to clean it. How would I remove the top layer of the screen? Because from what I can see it seems like it got squished between the glass and the actual LCD screen itself.
Carl Viernes - Responder Compartilhar
Me too, same issue, a very small bug I thaught was outside, acutally was inside and I squeezed it. It's very small but the dot is disturbing.
Is it possibile to take a part the layers of the LCD screen?
I have an ASUS PA248
Thank you
Piero - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 21
Últimos 7 dias: 149
Últimos 30 dias: 711
Ao todo: 137,016
