Ir para o conteúdo principal
ASUS UX50V-RX05 Optical Drive Replacement
O que você precisa
    1. ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: passo 1, imagem 1 %32 ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: passo 1, imagem 2 %32 ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: passo 1, imagem 3 %32
      • Make sure the device is powered off and the battery is removed before beginning.
      • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
      Pergunte ao FixBot
      Comentar
    2. ASUS UX50V-RX05 Optical Drive Replacement: passo 2, imagem 1 %32 ASUS UX50V-RX05 Optical Drive Replacement: passo 2, imagem 2 %32
      • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
      • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
      • Remove the cable after pushing out the two black clips.
      Pergunte ao FixBot
      Comentar
    3. ASUS UX50V-RX05 Optical Drive Replacement: passo 3, imagem 1 %32 ASUS UX50V-RX05 Optical Drive Replacement: passo 3, imagem 2 %32
      • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
      • Remove the cable after pushing out both black clips.
      • Remove the keyboard.
      Pergunte ao FixBot
      Comentar
    1. ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: passo 4, imagem 1 %32 ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: passo 4, imagem 2 %32 ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: passo 4, imagem 3 %32
      • Remove the thirteen 5 mm J0 screws from the back of the laptop.
      • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
      Pergunte ao FixBot
      Comentar
    2. ASUS UX50V-RX05 Optical Drive Replacement: passo 5, imagem 1 %32 ASUS UX50V-RX05 Optical Drive Replacement: passo 5, imagem 2 %32
      • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
      Pergunte ao FixBot
      Comentar
    3. ASUS UX50V-RX05 Optical Drive Replacement: passo 6, imagem 1 %32 ASUS UX50V-RX05 Optical Drive Replacement: passo 6, imagem 2 %32 ASUS UX50V-RX05 Optical Drive Replacement: passo 6, imagem 3 %32
      • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
      • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
      Pergunte ao FixBot
      Comentar
    4. ASUS UX50V-RX05 Optical Drive Replacement: passo 7, imagem 1 %32
      • Carefully lift and remove the plastic cover to avoid damaging anything.
      Pergunte ao FixBot
      Comentar
    1. ASUS UX50V-RX05 Optical Drive Replacement, Optical Drive: passo 8, imagem 1 %32 ASUS UX50V-RX05 Optical Drive Replacement, Optical Drive: passo 8, imagem 2 %32
      • Remove the four 5 mm J0 screws surrounding the Optical Drive.
      • Remove the optical drive by pulling it out and away from the connector.
      Pergunte ao FixBot
      Comentar
Conclusão
James
Membro desde: 02/14/17
663 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 20-2, Remmell Spring 2017 Membro de USF Tampa, Team 20-2, Remmell Spring 2017
USFT-REMMELL-S17S20G2
4 Membros
Autoria de 36 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 66
Ao todo: 522
