Ir para o conteúdo principal
ASUS UX50V-RX05 Motherboard Replacement
O que você precisa
  1. ASUS UX50V-RX05 Motherboard Replacement, Keyboard: passo 1, imagem 1 %32 ASUS UX50V-RX05 Motherboard Replacement, Keyboard: passo 1, imagem 2 %32 ASUS UX50V-RX05 Motherboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Make sure the device is powered off and the battery is removed before beginning.
    • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
    Pergunte ao FixBot
    Comentar
  2. ASUS UX50V-RX05 Motherboard Replacement: passo 2, imagem 1 %32 ASUS UX50V-RX05 Motherboard Replacement: passo 2, imagem 2 %32
    • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
    • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
    • Remove the cable after pushing out the two black clips.
    Pergunte ao FixBot
    Comentar
  3. ASUS UX50V-RX05 Motherboard Replacement: passo 3, imagem 1 %32 ASUS UX50V-RX05 Motherboard Replacement: passo 3, imagem 2 %32
    • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
    • Remove the cable after pushing out both black clips.
    • Remove the keyboard.
    Pergunte ao FixBot
    Comentar
  4. ASUS UX50V-RX05 Motherboard Replacement, Case Removal: passo 4, imagem 1 %32 ASUS UX50V-RX05 Motherboard Replacement, Case Removal: passo 4, imagem 2 %32 ASUS UX50V-RX05 Motherboard Replacement, Case Removal: passo 4, imagem 3 %32
    • Remove the thirteen 5 mm J0 screws from the back of the laptop.
    • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
    Pergunte ao FixBot
    Comentar
  5. ASUS UX50V-RX05 Motherboard Replacement: passo 5, imagem 1 %32 ASUS UX50V-RX05 Motherboard Replacement: passo 5, imagem 2 %32
    • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
    Pergunte ao FixBot
    Comentar
  6. ASUS UX50V-RX05 Motherboard Replacement: passo 6, imagem 1 %32 ASUS UX50V-RX05 Motherboard Replacement: passo 6, imagem 2 %32 ASUS UX50V-RX05 Motherboard Replacement: passo 6, imagem 3 %32
    • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
    • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
    Pergunte ao FixBot
    Comentar
  7. ASUS UX50V-RX05 Motherboard Replacement: passo 7, imagem 1 %32
    • Carefully lift and remove the plastic cover to avoid damaging anything.
    Pergunte ao FixBot
    Comentar
  8. ASUS UX50V-RX05 Motherboard Replacement, Optical Drive: passo 8, imagem 1 %32 ASUS UX50V-RX05 Motherboard Replacement, Optical Drive: passo 8, imagem 2 %32
    • Remove the four 5 mm J0 screws surrounding the Optical Drive.
    • Remove the optical drive by pulling it out and away from the connector.
    Pergunte ao FixBot
    Comentar
  9. ASUS UX50V-RX05 Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 ASUS UX50V-RX05 Motherboard Replacement, Motherboard: passo 9, imagem 2 %32 ASUS UX50V-RX05 Motherboard Replacement, Motherboard: passo 9, imagem 3 %32
    • Use the Plastic Opening Tool to unplug the blue cord on the Motherboard.
    Pergunte ao FixBot
    Comentar
  10. ASUS UX50V-RX05 Motherboard Replacement: passo 10, imagem 1 %32 ASUS UX50V-RX05 Motherboard Replacement: passo 10, imagem 2 %32
    • Remove the five 4 mm Phillips head 5 mm long screws that have white arrows pointing to them with the screwdriver.
    Pergunte ao FixBot
    Comentar
  11. ASUS UX50V-RX05 Motherboard Replacement: passo 11, imagem 1 %32 ASUS UX50V-RX05 Motherboard Replacement: passo 11, imagem 2 %32 ASUS UX50V-RX05 Motherboard Replacement: passo 11, imagem 3 %32
    • Lift the Motherboard with your fingers by reaching underneath the Motherboard and prying.
    Pergunte ao FixBot
    Comentar
  12. ASUS UX50V-RX05 Motherboard Replacement: passo 12, imagem 1 %32 ASUS UX50V-RX05 Motherboard Replacement: passo 12, imagem 2 %32 ASUS UX50V-RX05 Motherboard Replacement: passo 12, imagem 3 %32
    • Remove the two 4 mm Phillips head 5 mm long screws from the fan using the screwdriver.
    • Using the Spudger, carefully remove the white connector and lift the fan out of the casing.
    Pergunte ao FixBot
    Comentar
  13. ASUS UX50V-RX05 Motherboard Replacement: passo 13, imagem 1 %32 ASUS UX50V-RX05 Motherboard Replacement: passo 13, imagem 2 %32 ASUS UX50V-RX05 Motherboard Replacement: passo 13, imagem 3 %32
    • Slowly lift the motherboard up towards you being careful as to not rip any cords out of the bottom.
    • Using the Spudger, remove the connector towards the bottom of the motherboard.
    • Remove the motherboard from the casing.
    Pergunte ao FixBot
    Comentar
Conclusão
James
Membro desde: 02/14/17
663 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 20-2, Remmell Spring 2017 Membro de USF Tampa, Team 20-2, Remmell Spring 2017
USFT-REMMELL-S17S20G2
4 Membros
Autoria de 6 guias
1Comentário do guia
From your knowledge is that mother board from the asus ux50v upgrade-able? is the processor integrated into the board?
A Snow - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 25
Ao todo: 904
