Ir para o conteúdo principal
ASUS UX50V-RX05 Hard Drive Replacement
O que você precisa
  1. ASUS UX50V-RX05 Hard Drive Replacement, Keyboard: passo 1, imagem 1 %32 ASUS UX50V-RX05 Hard Drive Replacement, Keyboard: passo 1, imagem 2 %32 ASUS UX50V-RX05 Hard Drive Replacement, Keyboard: passo 1, imagem 3 %32
    • Make sure the device is powered off and the battery is removed before beginning.
    • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
    Pergunte ao FixBot
    Comentar
  2. ASUS UX50V-RX05 Hard Drive Replacement: passo 2, imagem 1 %32 ASUS UX50V-RX05 Hard Drive Replacement: passo 2, imagem 2 %32
    • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
    • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
    • Remove the cable after pushing out the two black clips.
    Pergunte ao FixBot
    Comentar
  3. ASUS UX50V-RX05 Hard Drive Replacement: passo 3, imagem 1 %32 ASUS UX50V-RX05 Hard Drive Replacement: passo 3, imagem 2 %32
    • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
    • Remove the cable after pushing out both black clips.
    • Remove the keyboard.
    Pergunte ao FixBot
    Comentar
  4. ASUS UX50V-RX05 Hard Drive Replacement, Case Removal: passo 4, imagem 1 %32 ASUS UX50V-RX05 Hard Drive Replacement, Case Removal: passo 4, imagem 2 %32 ASUS UX50V-RX05 Hard Drive Replacement, Case Removal: passo 4, imagem 3 %32
    • Remove the thirteen 5 mm J0 screws from the back of the laptop.
    • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
    Pergunte ao FixBot
    Comentar
  5. ASUS UX50V-RX05 Hard Drive Replacement: passo 5, imagem 1 %32 ASUS UX50V-RX05 Hard Drive Replacement: passo 5, imagem 2 %32
    • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
    Pergunte ao FixBot
    Comentar
  6. ASUS UX50V-RX05 Hard Drive Replacement: passo 6, imagem 1 %32 ASUS UX50V-RX05 Hard Drive Replacement: passo 6, imagem 2 %32 ASUS UX50V-RX05 Hard Drive Replacement: passo 6, imagem 3 %32
    • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
    • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
    Pergunte ao FixBot
    Comentar
  7. ASUS UX50V-RX05 Hard Drive Replacement: passo 7, imagem 1 %32
    • Carefully lift and remove the plastic cover to avoid damaging anything.
    Pergunte ao FixBot
    Comentar
  8. ASUS UX50V-RX05 Hard Drive Replacement, Hard Drive: passo 8, imagem 1 %32 ASUS UX50V-RX05 Hard Drive Replacement, Hard Drive: passo 8, imagem 2 %32
    • Using the screwdriver with the JO bit, remove the two Phillips 4 mm head size 5 mm long screws from the Hard Drive.
    Pergunte ao FixBot
    Comentar
  9. ASUS UX50V-RX05 Hard Drive Replacement: passo 9, imagem 1 %32 ASUS UX50V-RX05 Hard Drive Replacement: passo 9, imagem 2 %32
    • Flip the Hard Drive over without lifting.
    • Using your fingers, unplug the cord by pulling it away from the hard drive.
    Pergunte ao FixBot
    Comentar
  10. ASUS UX50V-RX05 Hard Drive Replacement: passo 10, imagem 1 %32
    • Unscrew the four black screws from the Hard Drive and slide it out.
    Pergunte ao FixBot
    Comentar
Conclusão
James
Membro desde: 02/14/17
663 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 20-2, Remmell Spring 2017 Membro de USF Tampa, Team 20-2, Remmell Spring 2017
USFT-REMMELL-S17S20G2
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 40
Ao todo: 1,058
