Ir para o conteúdo principal
ASUS ROG Strix GL503VD-DB71 Battery Replacement
O que você precisa
  1. ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: passo 1, imagem 1 %32 ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Start with flipping the laptop over so that the bottom side is facing up.
  2. ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 2, imagem 1 %32 ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 2, imagem 2 %32 ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 2, imagem 3 %32
    • Remove the screw for the small panel with a Phillips #1 screwdriver.
    • Use your plastic opening tool to lift up the cover to remove it.
    • Remove the screw beneath the service cover with a Phillips #1 screwdriver.
  3. ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 3, imagem 1 %32 ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 3, imagem 2 %32 ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 3, imagem 3 %32
    • Remove the 9 screws around the perimeter of the back case with a Phillips #1 screwdriver.
    • Use a plastic opening tool to pry the back cover off of the device.
    • Remove the back cover exposing the battery.
  4. ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 4, imagem 1 %32 ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 4, imagem 2 %32 ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 4, imagem 3 %32
    • Remove the single screw securing the battery with a Phillips #1 screwdriver.
    • Gently pull the battery cable from its connector on the motherboard.
    • Lift up on the battery to remove it.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 73
Duração total: 5,275
