Ir para o conteúdo principal
ASUS Q405U Hard Drive Replacement
O que você precisa
  1. ASUS Q405U Hard Drive Replacement, Back Cover: passo 1, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
    Pergunte ao FixBot
    Comentar
  2. ASUS Q405U Hard Drive Replacement: passo 2, imagem 1 %32
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
    Pergunte ao FixBot
    Comentar
  3. ASUS Q405U Hard Drive Replacement: passo 3, imagem 1 %32 ASUS Q405U Hard Drive Replacement: passo 3, imagem 2 %32 ASUS Q405U Hard Drive Replacement: passo 3, imagem 3 %32
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
    Pergunte ao FixBot
    Comentar
  4. ASUS Q405U Hard Drive Replacement: passo 4, imagem 1 %32 ASUS Q405U Hard Drive Replacement: passo 4, imagem 2 %32
    • OPTIONAL: Additional pictures to demonstrate moving keyboard out of the way without detaching connections.
    • Lift the ribbon cable with gentle pressure, pry the ribbon away from the motherboard on the right side, then the left, then the center, prying away only a little triangle of tape at a time, applying gentle upward pressure to the tape while you loosen and pry.
    • Once you have enough slack in the three ribbons that hold the keyboard down too tightly, lift the front of the keyboard and twist counterclockwise to produce enough room to reach the screws securing the hard drive with your screwdriver.
    Pergunte ao FixBot
    Comentar
  5. ASUS Q405U Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32
    • Remove the narrow strip of tape to the left of the hard drive.
    • Remove the five screws holding the caddy in.
    • Lift the hard drive slight;y and slide it to the right to remove it from its socket.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 2-8, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G8
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 46
Ao todo: 1,711
