Ir para o conteúdo principal
ASUS Q302L Trackpad Replacement
O que você precisa
  1. ASUS Q302L Trackpad Replacement, Back Case: passo 1, imagem 1 %32
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Trackpad Replacement: passo 2, imagem 1 %32 ASUS Q302L Trackpad Replacement: passo 2, imagem 2 %32 ASUS Q302L Trackpad Replacement: passo 2, imagem 3 %32
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Trackpad Replacement: passo 3, imagem 1 %32
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Trackpad Replacement, Battery: passo 4, imagem 1 %32
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Trackpad Replacement: passo 5, imagem 1 %32 ASUS Q302L Trackpad Replacement: passo 5, imagem 2 %32 ASUS Q302L Trackpad Replacement: passo 5, imagem 3 %32
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Trackpad Replacement: passo 6, imagem 1 %32 ASUS Q302L Trackpad Replacement: passo 6, imagem 2 %32
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Trackpad Replacement, Fan: passo 7, imagem 1 %32 ASUS Q302L Trackpad Replacement, Fan: passo 7, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
    • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
  8. ASUS Q302L Trackpad Replacement: passo 8, imagem 1 %32 ASUS Q302L Trackpad Replacement: passo 8, imagem 2 %32 ASUS Q302L Trackpad Replacement: passo 8, imagem 3 %32
    • Gently wedge two plastic prying tools on both sides of the black part of the connector.
    • Carefully pull out the connector from its socket.
  9. ASUS Q302L Trackpad Replacement: passo 9, imagem 1 %32 ASUS Q302L Trackpad Replacement: passo 9, imagem 2 %32
    • Once all screws and the connector are removed, you can safely pull the fan out of its place.
  10. ASUS Q302L Trackpad Replacement, Motherboard: passo 10, imagem 1 %32 ASUS Q302L Trackpad Replacement, Motherboard: passo 10, imagem 2 %32 ASUS Q302L Trackpad Replacement, Motherboard: passo 10, imagem 3 %32
    • Peel back the adhered strip to expose the black and white connections.
    • Pop the connections off the fixtures.
  11. ASUS Q302L Trackpad Replacement: passo 11, imagem 1 %32 ASUS Q302L Trackpad Replacement: passo 11, imagem 2 %32
    • Grasp the plastic tab of each connector with your fingers.
    • Firmly pull up, releasing the connectors one at a time.
  12. ASUS Q302L Trackpad Replacement: passo 12, imagem 1 %32 ASUS Q302L Trackpad Replacement: passo 12, imagem 2 %32
    • As in Step 8, gently pry out both sides of the white connector and pull out the connector.
  13. ASUS Q302L Trackpad Replacement: passo 13, imagem 1 %32 ASUS Q302L Trackpad Replacement: passo 13, imagem 2 %32 ASUS Q302L Trackpad Replacement: passo 13, imagem 3 %32
    • For each of the four marked connectors, gently insert a thin prying tool between the blue ribbon and grey tab.
    • Gently apply upward pressure evenly across the length of the tab.
    • Once the tab has snapped backwards, remove the blue ribbon.
  14. ASUS Q302L Trackpad Replacement: passo 14, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove the ten 4mm screws.
  15. ASUS Q302L Trackpad Replacement: passo 15, imagem 1 %32 ASUS Q302L Trackpad Replacement: passo 15, imagem 2 %32
    • Lift the Hinge gently up.
    • Lightly grasp the motherboard.
    • Lift the marked corner of the board first, then slide the corner of the board out from under the back corner of the case.
    • Place new thermal paste beneath the heatsink on the new motherboard.
  16. ASUS Q302L Trackpad Replacement, Trackpad: passo 16, imagem 1 %32 ASUS Q302L Trackpad Replacement, Trackpad: passo 16, imagem 2 %32 ASUS Q302L Trackpad Replacement, Trackpad: passo 16, imagem 3 %32
    • Carefully disconnect the ribbon connector from the touchpad using an iFixit opening tool.
    • Slowly peel the grounding strap off of the touchpad.
    • Use a Phillips #0 screwdriver to remove the three 2 mm screws holding the touchpad.
  17. ASUS Q302L Trackpad Replacement: passo 17, imagem 1 %32 ASUS Q302L Trackpad Replacement: passo 17, imagem 2 %32 ASUS Q302L Trackpad Replacement: passo 17, imagem 3 %32
    • Carefully lift and slide the touchpad towards the hinges using an iFixit opening tool.
    • Remove the touchpad.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 548
