Ir para o conteúdo principal
ASUS MeMo Pad FHD10 Battery Replacement
O que você precisa
    1. ASUS MeMo Pad FHD10 Battery Replacement, Battery: passo 1, imagem 1 %32 ASUS MeMo Pad FHD10 Battery Replacement, Battery: passo 1, imagem 2 %32
      • Make sure that the device is turned off as a precaution.
      • Unplug the charger and remove any memory card you may have in the device.
      • Wedge the plastic opening tool between the front and back cover on every side.
      • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
      • Once disconnected, remove the back cover from the device screen.
      Pergunte ao FixBot
      Comentar
    2. ASUS MeMo Pad FHD10 Battery Replacement: passo 2, imagem 1 %32 ASUS MeMo Pad FHD10 Battery Replacement: passo 2, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Remove the protective copper sticker and all tape fixed on the device.
      • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
      • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
      Pergunte ao FixBot
      Comentar
    3. ASUS MeMo Pad FHD10 Battery Replacement: passo 3, imagem 1 %32 ASUS MeMo Pad FHD10 Battery Replacement: passo 3, imagem 2 %32
      • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
      Pergunte ao FixBot
      Comentar
    4. ASUS MeMo Pad FHD10 Battery Replacement: passo 4, imagem 1 %32 ASUS MeMo Pad FHD10 Battery Replacement: passo 4, imagem 2 %32 ASUS MeMo Pad FHD10 Battery Replacement: passo 4, imagem 3 %32
      • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
      • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
      • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
      Pergunte ao FixBot
      Comentar
Conclusão
5 outras pessoas executaram este guia.
Dmitry
Membro desde: 01/21/15
391 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 9-5, Blackwell Winter 2015 Membro de USF Tampa, Team 9-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G5
4 Membros
Autoria de 10 guias
1Comentário do guia
Where i can get new battery for this tablet?
Night Knight - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 42
Ao todo: 10,788
