Ir para o conteúdo principal
ASUS K50IJ Screen replacement 15.6" Replacement
O que você precisa
  1. ASUS K50IJ Screen replacement 15.6" Replacement, Battery: passo 1, imagem 1 %32
    • Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
    Pergunte ao FixBot
    Comentar
  2. ASUS K50IJ Screen replacement 15.6" Replacement: passo 2, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 2, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 2, imagem 3 %32
    • Lift the exposed lip and remove the battery cover.
    Pergunte ao FixBot
    Comentar
  3. ASUS K50IJ Screen replacement 15.6" Replacement: passo 3, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 3, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 3, imagem 3 %32
    • Press the tabs on the battery and lift them. The battery should come out easily.
    Pergunte ao FixBot
    Comentar
  4. ASUS K50IJ Screen replacement 15.6" Replacement, Fan: passo 4, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement, Fan: passo 4, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement, Fan: passo 4, imagem 3 %32
    • Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
    Pergunte ao FixBot
    Comentar
  5. ASUS K50IJ Screen replacement 15.6" Replacement: passo 5, imagem 1 %32
    • Remove the one .5 mm screw located in the top right corner of the battery compartment.
    Pergunte ao FixBot
    Comentar
  6. ASUS K50IJ Screen replacement 15.6" Replacement: passo 6, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 6, imagem 2 %32
    • Remove the bottom panel by sliding it toward the hinges and lifting the back panel up.
    Pergunte ao FixBot
    Comentar
  7. ASUS K50IJ Screen replacement 15.6" Replacement: passo 7, imagem 1 %32
    • Unplug the wire cable attached to the fan by pulling it out .
    Pergunte ao FixBot
    Comentar
  8. ASUS K50IJ Screen replacement 15.6" Replacement: passo 8, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 8, imagem 2 %32
    • Using the PH1 screwdriver, remove the 3 .75mm screws labeled as 1, 2, and 3 on the fan. NOTE these screws have the labels "1", "2", and "3" next to them.
    • Lift the fan up with your fingers.
    Pergunte ao FixBot
    Comentar
  9. ASUS K50IJ Screen replacement 15.6" Replacement, Charging Port: passo 9, imagem 1 %32
    • Using the PH1 screwdriver remove the two .75 mm screws from the hinge side of the laptop.
    Pergunte ao FixBot
    Comentar
  10. ASUS K50IJ Screen replacement 15.6" Replacement: passo 10, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 10, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 10, imagem 3 %32
    • Using the PH1 screwdriver, remove the four .75 mm screws from the copper heat sync. They will be labeled 1-4.
    • Pull the copper heat sync out of the laptop.
    Pergunte ao FixBot
    Comentar
  11. ASUS K50IJ Screen replacement 15.6" Replacement: passo 11, imagem 1 %32
    • Using the PH1 screwdriver, remove four .75 mm screws from the driver, located in the bottom-right corner of the laptop.
    Pergunte ao FixBot
    Comentar
  12. ASUS K50IJ Screen replacement 15.6" Replacement: passo 12, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 12, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 12, imagem 3 %32
    • Pull on the black tab on the driver to slide the driver back, and lift the driver out of the laptop.
    Pergunte ao FixBot
    Comentar
  13. ASUS K50IJ Screen replacement 15.6" Replacement: passo 13, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 13, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 13, imagem 3 %32
    • Using the PH1 screwdriver, remove the five .5 mm screws from the SD card reader, located in the bottom-middle corner of the laptop.
    • Slide the SD card reader away and out.
    Pergunte ao FixBot
    Comentar
  14. ASUS K50IJ Screen replacement 15.6" Replacement: passo 14, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 14, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 14, imagem 3 %32
    • Detach the white and black wires from the Wi-Fi card, located in the central area of the laptop.
    Pergunte ao FixBot
    Comentar
  15. ASUS K50IJ Screen replacement 15.6" Replacement: passo 15, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 15, imagem 2 %32
    • Using the PH 1 screwdriver, remove the two .25 mm screws from the Wi-Fi card.
    Pergunte ao FixBot
    Comentar
  16. ASUS K50IJ Screen replacement 15.6" Replacement: passo 16, imagem 1 %32
    • Slide the Wi-Fi card out of its slot to remove.
    Pergunte ao FixBot
    Comentar
  17. ASUS K50IJ Screen replacement 15.6" Replacement: passo 17, imagem 1 %32
    • Using the PH1mm screwdriver, remove one .5 mm screw from the disk drive, located inthe top-right corner of the laptop.
    Pergunte ao FixBot
    Comentar
  18. ASUS K50IJ Screen replacement 15.6" Replacement: passo 18, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 18, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 18, imagem 3 %32
    • Slide the disc drive out of its slot.
    Pergunte ao FixBot
    Comentar
  19. ASUS K50IJ Screen replacement 15.6" Replacement: passo 19, imagem 1 %32
    • Using the PH 1 screwdriver, remove the two .5 mm screws from the RAM drive.
    Pergunte ao FixBot
    Comentar
  20. ASUS K50IJ Screen replacement 15.6" Replacement: passo 20, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 20, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 20, imagem 3 %32
    • Slide and lift the RAMdrive out of its port.
    Pergunte ao FixBot
    Comentar
  21. ASUS K50IJ Screen replacement 15.6" Replacement: passo 21, imagem 1 %32
    • Using the PH1 screwdriver, remove the .75 mm screw from the plastic housing corner, located in the bottom-right corner of the laptop.
    Pergunte ao FixBot
    Comentar
  22. ASUS K50IJ Screen replacement 15.6" Replacement: passo 22, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 22, imagem 2 %32
    • Unplug the black cable from the central area of the laptop.
    Pergunte ao FixBot
    Comentar
  23. ASUS K50IJ Screen replacement 15.6" Replacement: passo 23, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 23, imagem 2 %32
    • Unplug the wire cable in the central area of the laptop.
    Pergunte ao FixBot
    Comentar
  24. ASUS K50IJ Screen replacement 15.6" Replacement: passo 24, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 24, imagem 2 %32
    • Unplug the wire and black cables on the motherboard, located in the upper-left corner of the laptop.
    Pergunte ao FixBot
    Comentar
  25. ASUS K50IJ Screen replacement 15.6" Replacement: passo 25, imagem 1 %32
    • Using the PH1 screwdriver, unscrew the two .75 mm screws from the top-left corner of the motherboard.
    Pergunte ao FixBot
    Comentar
  26. ASUS K50IJ Screen replacement 15.6" Replacement: passo 26, imagem 1 %32
    • Using the PH 1 screwdriver, remove the .75 cm screw from the top-middle section of the motherboard.
    Pergunte ao FixBot
    Comentar
  27. ASUS K50IJ Screen replacement 15.6" Replacement: passo 27, imagem 1 %32
    • Using the PH1 screwdriver, remove the .75 mm screw from the top-middle corner of the motherboard.
    Pergunte ao FixBot
    Comentar
  28. ASUS K50IJ Screen replacement 15.6" Replacement: passo 28, imagem 1 %32
    • Using the PH1 screwdriver, remove the three .75 mm screws from the bottom corner of the motherboard.
    Pergunte ao FixBot
    Comentar
  29. ASUS K50IJ Screen replacement 15.6" Replacement: passo 29, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 29, imagem 2 %32
    • There is a ribbon cable connected to the back of the motherboard. Be careful not to break the ribbon cable.
    • Slide the motherboard to the right and lift it up, but do not pull it completely out.
    Pergunte ao FixBot
    Comentar
  30. ASUS K50IJ Screen replacement 15.6" Replacement: passo 30, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 30, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 30, imagem 3 %32
    • Gently unplug the ribbon cable from the underside of the motherboard.
    Pergunte ao FixBot
    Comentar
  31. ASUS K50IJ Screen replacement 15.6" Replacement: passo 31, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 31, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 31, imagem 3 %32
    • The ribbon cable that was plugged into the motherboard is attached to the keyboard. Be sure not to damage it.
    • Use the metal spudger or opening tool across the top edge of the keyboard to pop it out.
    Pergunte ao FixBot
    Comentar
  32. ASUS K50IJ Screen replacement 15.6" Replacement: passo 32, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 32, imagem 2 %32
    • Use the metal spudger or opening tool to pop out the plastic hinge covers.
    Pergunte ao FixBot
    Comentar
  33. ASUS K50IJ Screen replacement 15.6" Replacement: passo 33, imagem 1 %32
    • Use the PH1 screwdriver to remove the .75 mm screws from the hinges. Each hinge has one screw.
    Pergunte ao FixBot
    Comentar
  34. ASUS K50IJ Screen replacement 15.6" Replacement: passo 34, imagem 1 %32
    • Be careful not to damage the cables that are attached to the screen frame. Be sure to pull them through the laptop carefully.
    • The screen should separate from the rest of the laptop.
    Pergunte ao FixBot
    Comentar
  35. ASUS K50IJ Screen replacement 15.6" Replacement: passo 35, imagem 1 %32
    • Using the PH1 screwdriver, remove the .75 mm screw from the bottom-middle section was previously covering.
    Pergunte ao FixBot
    Comentar
  36. ASUS K50IJ Screen replacement 15.6" Replacement: passo 36, imagem 1 %32
    • Using the PH 1 screwdriver, remove the .75 cm screw from the bottom-middle section where the keyboard was previously covering.
    Pergunte ao FixBot
    Comentar
  37. ASUS K50IJ Screen replacement 15.6" Replacement: passo 37, imagem 1 %32
    • Lift the front cover off of the laptop.
    Pergunte ao FixBot
    Comentar
  38. ASUS K50IJ Screen replacement 15.6" Replacement: passo 38, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 38, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 38, imagem 3 %32
    • Flip the laptop back over. The charging port will be located in the top-right corner.
    Pergunte ao FixBot
    Comentar
  39. ASUS K50IJ Screen replacement 15.6" Replacement, Screen replacement 15.6": passo 39, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement, Screen replacement 15.6": passo 39, imagem 2 %32
    • Using a metal spudger, pop off the six rubber screw covers.
    Pergunte ao FixBot
    Comentar
  40. ASUS K50IJ Screen replacement 15.6" Replacement: passo 40, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 40, imagem 2 %32
    • Using the PH1mm screwdriver, remove the six .75 mm screws from the front of the screen frame.
    Pergunte ao FixBot
    Comentar
  41. ASUS K50IJ Screen replacement 15.6" Replacement: passo 41, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 41, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 41, imagem 3 %32
    • Use the plastic opening tool or spudger along the edge of the frame, to pry off the frame.
    Pergunte ao FixBot
    Comentar
  42. ASUS K50IJ Screen replacement 15.6" Replacement: passo 42, imagem 1 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 42, imagem 2 %32 ASUS K50IJ Screen replacement 15.6" Replacement: passo 42, imagem 3 %32
    • Using the PH1 screwdriver, remove the four bottom .75 mm screws from the screen frame.
    Pergunte ao FixBot
    Comentar
  43. ASUS K50IJ Screen replacement 15.6" Replacement: passo 43, imagem 1 %32
    • Using the PH1 screwdriver, remove the two .75 cm screws from the top of the screen frame.
    Pergunte ao FixBot
    Comentar
  44. ASUS K50IJ Screen replacement 15.6" Replacement: passo 44, imagem 1 %32
    • Lift the bracket off the top of the screen frame.
    Pergunte ao FixBot
    Comentar
  45. ASUS K50IJ Screen replacement 15.6" Replacement: passo 45, imagem 1 %32
    • Lift the screen should out.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
3Comentários do guia
Very well done. Thank You
Rc wells - Responder Compartilhar
Thank you for your time!
tatiana.morais.89 - Responder Compartilhar
Now, I don´t know how to connect the cables to the motherboard because they are too short.
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 1,608
